V8 exhaust manifolds for Ninety/Defender 90
Just curious, does anyone know of any options for some exhaust manifolds for a V8 90?
The vehicle in question is a factory V8 with the LT-85. It had a custom stainless exhaust many years ago, basically from the Y piece back. We fitted new downpipes then. But one has rotted through and looks like the actual log manifold has had it too.
I've seen some tubular manifolds listed for Classic Range Rover's and the p38 seems to use a different manifold.
But does anyone know what fits and works on a 90? Not sure how much bulkhead and chassis clearance there is by comparison.
Thanks.
there are stainless tubular manifolds an full systems available from rimmers not cheap tho headman headders do steel tubular manifolds also if you want to save a few quid you could fit cast manifolds an make something fit yourself    I was using 3.9 cast manifolds rrc y piece with the slightest of tweeks with a standard rear pipe an make a pipe to go between the y piece an rear pipe anything is possible with grinder an welder
