danielfilipe Posted June 8, 2017 Share Posted June 8, 2017 hi. i have a 6Bolt pas box and lately i have LOTS of play in the steering, i have repaired a failure on the input shaft i had no power steering to my left side only to the right i solved that, now the play is almost half of the steering wheel is there any known fix to this? ( the bolt on the top of the pas box is tightened allmost to the end) i opened the box and dont see any extensive wear to the scroll gears , at first sight i have a 2mm "gap" where the 2 gears meet. and i think my output shaft scroll is a bit loose any help? Quote Link to comment Share on other sites More sharing options...
zardos Posted June 8, 2017 Share Posted June 8, 2017 Solution replace the 6 bolt box with a new or reconditioned 4 bolt Box (that is what I did as 6 bolts are obsolete and no longer made which makes reconditioning more difficult where as the 4 bolts are still manufactured by Adwest) (you need to change the steering arm as well for this conversion) Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 8, 2017 Share Posted June 8, 2017 The 6-bolts are heavy-duty (as fitted to 127/130) and the 4-bolts are "light duty" (according to the parts book) so it depends what it's on, I'm a little wary of replacing the 6-bolt on the ambulance with anything "light duty" lest I have to explain to a policeman why my steering failed and I hit the proverbial busload of nuns... I picked up a spare 6-bolt at Sodbury for £10 so they are around. 1 Quote Link to comment Share on other sites More sharing options...
zardos Posted June 8, 2017 Share Posted June 8, 2017 The general consensus seems to suggest that the 4 bolt is more robust than the 6 bolt. But if you do want to try and repair it then the post Might help Quote Link to comment Share on other sites More sharing options...
zardos Posted June 8, 2017 Share Posted June 8, 2017 Looking at parts book I see nothing about "light duty" only "lightweight" and the 6 bolt unit does weigh more or it could mean the weight feel of the steering, but it does seem that Landrover did stop using 6 bolts for some reason (may be because they were not as good?) Quote Link to comment Share on other sites More sharing options...
Maverik Posted June 8, 2017 Share Posted June 8, 2017 I don't know what the backlash is for those boxes but it must be relatively tight, does the play of the input shaft relate to the gap you can see, if so there isn't an adjustment for that kind of looseness, its just down to wear of components. I tried to find a new main sector shaft, but no joy at all in finding any spares for the 6 bolt. Considering they've fit the 4 bolt type to every recent iteration of Defender for the past heaven know how many years, including hi-caps, 130's etc etc, I doubt there is need to worry about the "duty" of the units. Having said that Hobsons are still selling them at a somewhat exuberant price... https://hobsonlandroverparts.com/collections/defender-90-and-110-parts-steering/products/ntc1582 Quote Link to comment Share on other sites More sharing options...
danielfilipe Posted June 8, 2017 Author Share Posted June 8, 2017 all the bearings and seals are new, is there anyplace where i can buy some pas boxes? if i could find one with no play but with a fault on the power steering ( only powered for one side) it would be great, this problem is fairly ease to solve and i could repair it myself, the general idea is to maintain a 6 bolt gemmer ( i´m Portuguese so sorry for bad english ) Quote Link to comment Share on other sites More sharing options...
danielfilipe Posted June 8, 2017 Author Share Posted June 8, 2017 this video might help a bit ff.mp4 Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted June 8, 2017 Share Posted June 8, 2017 They are fitted to UMM Alter 2 Quote Link to comment Share on other sites More sharing options...
danielfilipe Posted June 8, 2017 Author Share Posted June 8, 2017 correct Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted June 9, 2017 Share Posted June 9, 2017 I know. I was more suggesting that Portugal has the largest concentration of UMM Alter2 's in the known universe; and as such there may be one or two in scrap yards Quote Link to comment Share on other sites More sharing options...
