sighnbox Posted July 31, 2017 Share Posted July 31, 2017 Just quick one guys and prob don't matter but being a perfectionist and wanting what's dead right for me landy it is bugging me 1990 110 was TD now fitted with 200tdi so not sure what rest of her is But the power steering box is a 5 bolt type What ATF guys ??? Dexron 2 or 3 .......I have been using Dexron 2 ATF-Q.....But been told it should be Dexron 3 ATF-G .......????? And while I'm here brake and clutch fluid .....Dot 3 or Dot 4 ..???? Thanks Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 31, 2017 Share Posted July 31, 2017 Either type of ATF will be fine Likewise brake fluid, DOT 3 or DOT 4 will both cause no problems. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 31, 2017 Share Posted July 31, 2017 Fluids are generally backwards compatible, so while an original manual may specify Dexron 2, 3 or 4 or even 5 should actually be fine. A couple of exceptions are GL4 and GL5 EP oils, for the older gearboxes you do want GL4 to protect the bronze bits. Brake fluid - DoT 5 is silicon, you don't want to mix this with 3 or 4, but will work fine in a system designed for 3 or 4 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 31, 2017 Share Posted July 31, 2017 Trouble with Dot 5 is it rots rubber, not so good for seals. Mo Quote Link to comment Share on other sites More sharing options...
