simonpelly Posted January 4, 2018 Share Posted January 4, 2018 Hi Folks, Firstly, Happy New Year all. Another year of Defender fun awaits. Looking for confirmation of the W connector on the alternator. Currently hooking up to a rev counter that is being fitted. Defender 300Tdi 1997 Wanted to double check since was not expecting to see any other wire connected to this. The wire seems to connect to a "black box" on the other side of the alternator. Many Thanks, Simon... Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted January 4, 2018 Share Posted January 4, 2018 Not sure but was told by someone that the black box is to stop interference with the radio and the wire was an earth , if I’m wrong someone will be along to put you wright . just looked at second photo you’ve got 2 so might be totally wrong. cheers Ian Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 4, 2018 Share Posted January 4, 2018 Yes, that is why there is a "W" on the case next to it. Someone has hooked the suppressor to the wrong connector. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted January 4, 2018 Share Posted January 4, 2018 The wires in that photo are in the factory location. There are 2 suppressors and they wire in a cross pattern. The white/slate wire spade connector to the W terminal connects to the EGR ECU. You can remove that if you have removed your EGR. Quote Link to comment Share on other sites More sharing options...
simonpelly Posted January 8, 2018 Author Share Posted January 8, 2018 Hi Folks, Thanks for all the help. Finished fitting the rev counter and it works a treat. Only needed a tweak to the dip switches on the rear of the rev counter for calibration. Simon... 1 Quote Link to comment Share on other sites More sharing options...
