14Platoon Posted January 17, 2018 Share Posted January 17, 2018 I’ve just purchased an oil temperature sender for my military defender 90 on a 1992 Diesel n/a. The electrical connection end isn’t a spade connection? How do I connect the electrical end to the supply? thanks Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 17, 2018 Share Posted January 17, 2018 It uses a 1/4" female spade connector sideways. Really..... Quote Link to comment Share on other sites More sharing options...
lo-fi Posted January 17, 2018 Share Posted January 17, 2018 (edited) A female spade connector - the type without the insulation boot the whole way down - slips over the round endy bit like it's a male spade at a right angle to the sensor. Edit: ninja'd by Red 90 Edited January 17, 2018 by lo-fi Ninja'd Quote Link to comment Share on other sites More sharing options...
14Platoon Posted January 17, 2018 Author Share Posted January 17, 2018 (edited) 16 minutes ago, lo-fi said: A female spade connector - the type without the insulation boot the whole way down - slips over the round endy bit like it's a male spade at a right angle to the sensor. Edit: ninja'd by Red 90 Excellent replies and quick too! Cheers Edited January 17, 2018 by 14Platoon Quote Link to comment Share on other sites More sharing options...
14Platoon Posted January 17, 2018 Author Share Posted January 17, 2018 Ps the metal connection at the end is bent, I’m assuming it’s suposed to be that way? It doesn’t really show the bend in my photo though. Quote Link to comment Share on other sites More sharing options...
western Posted January 17, 2018 Share Posted January 17, 2018 the disc on end of the pin should be square to the sender body, not bent, just take care when sliding the spade terminal on, pretty sure the question on how does it connect has been asked before. Quote Link to comment Share on other sites More sharing options...
14Platoon Posted January 17, 2018 Author Share Posted January 17, 2018 It’s definitely bent! Quote Link to comment Share on other sites More sharing options...
14Platoon Posted January 28, 2018 Author Share Posted January 28, 2018 Changed the sensor and still no working gauge. Any ideas how to fix a gauge? It looks expensive to buy a new one. Quote Link to comment Share on other sites More sharing options...
Mutley Posted January 28, 2018 Share Posted January 28, 2018 Part number......PRC2158 Genuine LR on Ebay £19.99 if thats the one? Guys only got one left though. Andy Quote Link to comment Share on other sites More sharing options...
western Posted January 28, 2018 Share Posted January 28, 2018 prc2158 is a Series LR oil temp gauge, won't work on a 90/110, you need prc7138 --- https://www.johncraddockltd.co.uk/land-rover-defender/defender-90-and-110/parts/instruments-and-cables/prc7318-oil-temp-gauge-90-110-to-1994.html That's what I had in my 110, it got replaced with a VDO unit sometime ago, old gauge was sold. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 28, 2018 Share Posted January 28, 2018 8 hours ago, 14Platoon said: Changed the sensor and still no working gauge. Any ideas how to fix a gauge? It looks expensive to buy a new one. You need to check the wiring. Do you have power to the gauge? Is there power at the sender? Gauges are easy to check. Disconnect the sender wire and it should go one way. Ground the sender wire and it should go the other way. Quote Link to comment Share on other sites More sharing options...
western Posted January 28, 2018 Share Posted January 28, 2018 gauge needs the earth on the centre post on top of the U clamp with knurled edged nut on top, connects to the other gauge earth points a 12v feed to the + terminal & the signal wire from sender to the other terminal, just ensure the U clamp does not touch any other metal part of it's gauge or you'll have a direct path to earth. Quote Link to comment Share on other sites More sharing options...
