miketomcat
Ok I've had enough now
Having driven 45 it judders at low speed especially when coming to a stop :blink:. I've jacked up each wheel and spun it. There doesn't seem to be any tight spots or noise. The only thing I can find is if I spin the front prop I can feel a slight snagging through the hand brake drum even with the t box in neutral. If I remember correctly the output bearings can be changed in situ but I'm concerned this maybe a waste of time. Looks like a replacement t box is on the cards. Oh joy I haven't done any spannering for at least 2 days. :angry:
Mike
Share this post
Link to post
Sounds like the handbrake wants adjusting. Dragging shoes can cause vibration coming to a stop
Share this post
Link to post
Posted (edited)
I don't think it is as it spun freely when I had a wheel lifted but I will check.
Mike
The way my luck has been running recently I'm thinking a collapsed bearing.
Edited by miketomcat
Share this post
Link to post
classic symptoms of HB issues - jammed expander, oil on shoes , clips and springs off or even a broken lining .
cheers
Steve b
Share this post
Link to post
For the sake of it Mike, probably worth detaching the rear prop and knocking the tbox into neutral and spinning the drum by hand.
Equally you could just drop the plate off the bottom and wiggle bits inside. Having just done that I had kaput bearings so got a replacement from Ashcrofts.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
