NeilF Posted September 22, 2018 Share Posted September 22, 2018 My Disco2's alarm seems to be having an identity crisis. Shortly after locking the car with the key fob, 3 or 4 mins, the alarm will suddenly go off without any intervention. It takes repeated presses of the key fob to turn it off. Thereafter, the dashboard LED lights with a continuous rapid flash until I turn on the ignition. My immediate thought was that the key fob battery was on its way out, so I replaced that, but to no avail. Any ideas? Quote Link to comment Share on other sites More sharing options...
bear Posted September 22, 2018 Share Posted September 22, 2018 (edited) Hi Neil, Try locking it with the key and see if it still goes off. This will rule out the volumetric sensor/s that detect movement inside the vehicle. I've read guys having problems with moths causing this. The LED is flashing to notify you the alarms be activated. Regards, Griff Edited September 22, 2018 by bear Quote Link to comment Share on other sites More sharing options...
NeilF Posted September 22, 2018 Author Share Posted September 22, 2018 OK, I'll try that, though the problem is very intermittent - I hate intermittent problems! Quote Link to comment Share on other sites More sharing options...
teabag Posted September 22, 2018 Share Posted September 22, 2018 (edited) The rapid flashing of the LED will notify you that alarm is inactive. The ultrasonic sensor can go over sensitive if faulty, locking will isolate that item. I assume that the central locking is fully functional so no issues there. Edited September 22, 2018 by teabag Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 23, 2018 Share Posted September 23, 2018 On some vehicles, and I forget which ones, there was a problem at one point with the interior sensor getting damp inside and causing random alarms. You can tell what the previous alarm triggers were caused by with a diagnostic, which is the best way. But locking with the key will isolate that sensor as a test, as stated above. Quote Link to comment Share on other sites More sharing options...
