Patrick501 Posted September 28, 2018 Share Posted September 28, 2018 Quote Link to comment Share on other sites More sharing options...
Patrick501 Posted September 28, 2018 Author Share Posted September 28, 2018 The Original alternator has a spade connection next to the W terminal The new alternator does not, both are 65 amp units can anyone shed any light on this Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 28, 2018 Share Posted September 28, 2018 It is just a second condenser. Does not matter. You should have bought a 100A unit, if you were getting a new one. They don't cost much more. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted September 28, 2018 Share Posted September 28, 2018 You could try taking off the plastic spade attachment to put on the new alternator. What part number did you buy? The one on the right is AMR4249 Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted September 29, 2018 Share Posted September 29, 2018 19 hours ago, Red90 said: It is just a second condenser. Does not matter. You should have bought a 100A unit, if you were getting a new one. They don't cost much more. you would also need the uprated cable to go with the 100a Quote Link to comment Share on other sites More sharing options...
Patrick501 Posted September 29, 2018 Author Share Posted September 29, 2018 New alternator fitted did not use the spade connection in the end, just taped it off. System now working checked battery voltage when engine is running and approx 14.8 volts. If I was fitting a 100amp unit I would also have to upgrade the main cable from the alternator. Thanks anyway patrick Quote Link to comment Share on other sites More sharing options...
western Posted September 29, 2018 Share Posted September 29, 2018 The W terminal on both is the stud & nut marked, the spade terminal just slides on the W terminal stud, my 100amp alt is similar, but I fitted a ring end to my rev counter wire to fit the W terminal stud. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 29, 2018 Share Posted September 29, 2018 A cable costs very little. Not sure why that would stop you. Quote Link to comment Share on other sites More sharing options...
