PeteMck Posted March 3, 2019 Author Share Posted March 3, 2019 (edited) yer thats pretty much what it looks like. I machined a plug at work to fit in there. Seems to have done the trick. I can now get the engine down to 600rpm and if i completely close the throttle it will stall. With a bit of playing with the map im hoping ill be able to get a steady idle at around 750/800rpm. its already a lot better. my next issue is how little throttle movement i need before its revving its rubbish off. probably not even 1/4 open and its up at 5000rpm. is this probably just down to my ve table? Also what do you guys have your injector staging (simultaneous or alternating) and how many squirts per cycle? TIA Edited March 3, 2019 by PeteMck Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 3, 2019 Share Posted March 3, 2019 Well that's progress! If you can stall it with the throttle closed it sounds like you're basically air-tight, so that's a good starting base-line. With no load you don't need much throttle opening to get it to rev up, don't start panicking about fuel maps etc. just yet - if it starts & runs & idles there's not much wrong with anything. I will try and remember to dig a base map etc. off the laptop when I'm next in the shed. Quote Link to comment Share on other sites More sharing options...
PeteMck Posted March 4, 2019 Author Share Posted March 4, 2019 Well that's encouraging. Taken me long enough to find the leak 🙄 A base map would be good! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 4, 2019 Share Posted March 4, 2019 Let's see if I tag @Hybrid_From_Hell and @Bowie69 and see who among us can post a base map for a 4.6 first Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 4, 2019 Share Posted March 4, 2019 I don't think I have a 4.6 spark map -I tend to prefer the revvier 4.0/3.9s. Quote Link to comment Share on other sites More sharing options...
PeteMck Posted March 12, 2019 Author Share Posted March 12, 2019 which is better 2 or 4 squirts per cycle and should it be simultaneous or alternating? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 12, 2019 Share Posted March 12, 2019 OK this is the basic defaults blown into Nige's ECU's - should start & run anything but don't take it as the perfect settings, just as a rough guide: http://www.fuddymuckers.co.uk/files/ms/_MS_N_EDIS_Defaults.msq And this is the msq from my 4.6 in the 127, beware it has outputs for fan control set up and is by no means a good tune (I can build 'em but I suck at tuning): http://www.fuddymuckers.co.uk/files/ms/127_megasquirt201807171849.msq Quote Link to comment Share on other sites More sharing options...
PeteMck Posted March 13, 2019 Author Share Posted March 13, 2019 cheers for that. when i try and open them it just gives me this. do i just have to enter it all manually? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 13, 2019 Share Posted March 13, 2019 Save it, and upload to the ecu. Quote Link to comment Share on other sites More sharing options...
PeteMck Posted March 13, 2019 Author Share Posted March 13, 2019 at the risk of sounding stupid, how do i save it? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 13, 2019 Share Posted March 13, 2019 Right click - save as Quote Link to comment Share on other sites More sharing options...
PeteMck Posted March 15, 2019 Author Share Posted March 15, 2019 these are the only options it give me 😕 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 15, 2019 Share Posted March 15, 2019 Save link as... Quote Link to comment Share on other sites More sharing options...
PeteMck Posted March 15, 2019 Author Share Posted March 15, 2019 success! cheers guys. will give that a try this weekend 🤞 Quote Link to comment Share on other sites More sharing options...
Daragh Posted April 6, 2019 Share Posted April 6, 2019 On 3/3/2019 at 3:41 PM, PeteMck said: yer thats pretty much what it looks like. I machined a plug at work to fit in there. Seems to have done the trick. I can now get the engine down to 600rpm and if i completely close the throttle it will stall. With a bit of playing with the map im hoping ill be able to get a steady idle at around 750/800rpm. its already a lot better. my next issue is how little throttle movement i need before its revving its rubbish off. probably not even 1/4 open and its up at 5000rpm. is this probably just down to my ve table? Also what do you guys have your injector staging (simultaneous or alternating) and how many squirts per cycle? TIA Good morning PeteMck, I think I am having the same problem and need to seal my defunct stepper. Did you machine a piece with a conical end to match the stepper or was it just a cylinder shape in as far as possible. This may save me pulling the last few hairs out of my head in frustration if it solves it. Tks in advance for any advice. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 6, 2019 Share Posted April 6, 2019 You can do almost anything as long as air can't get through the passage - I have a feeling I may have tapped the inlet channel and wound a short socket-cap bolt in on one of them, the other I machined a pin with a head and pushed it into the hole. Quote Link to comment Share on other sites More sharing options...
Daragh Posted April 6, 2019 Share Posted April 6, 2019 Tks FF. I think I found the solution 😀 Quote Link to comment Share on other sites More sharing options...
