Christopherdefender Posted December 1, 2018 Share Posted December 1, 2018 Hello. I have I defender 90 300 tdi and just installed a boost pin. I heard that it could be bad for the turbo and for the EGT. the car is 100% stock and got so much more power with the boost pin and therefore wonder if I should go back to the original one. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 1, 2018 Share Posted December 1, 2018 Anything that increases the power output of an engine will reduce its service life. It depends what you value. if I were fitting a boost pin and playing I would definitely have an EGT gauge fitted. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted December 1, 2018 Share Posted December 1, 2018 (edited) Yes. If the EGTs are too high, you can destroy the turbo and melt pistons. Fit an EGT gauge and learn how to adjust the injection pump. Edited December 1, 2018 by Red90 Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted December 2, 2018 Share Posted December 2, 2018 For ECU engines you pay £100's to a (hopefully reputable) company that measures your engine's characteristics and tunes it to what it needs. For mechanical engines, you pay £15 for a metal shaft machined by a bloke in a shed, with no data to back it up or understanding of how your engine will react That was tongue in cheek, but the margin for error in the latter is a lot larger, so engine damage is a real possibility. Whether that happens in 100 miles, 30k miles or never, no-one knows for your engine. An EGT gauge would be wise, as well as regular servicing. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 3, 2018 Share Posted December 3, 2018 22 hours ago, dailysleaze said: For ECU engines you pay £100's to a (hopefully reputable) company that measures your engine's characteristics and tunes it to what it needs. For mechanical engines, you pay £15 for a metal shaft machined by a bloke in a shed, with no data to back it up or understanding of how your engine will react Quite aptly put I'd say! Also people will fit a boost pin and/or tweak the pump on an engine/injector pump that's done 200k and is in desperate need of a damn good service / recon. And with no EGT gauge... Quote Link to comment Share on other sites More sharing options...
Ex Member Posted December 3, 2018 Share Posted December 3, 2018 At lest in this case, the owner is looking for advice. So...it makes sense to be helpful and supportive instead of denigrating. Quote Link to comment Share on other sites More sharing options...
