broken90 Posted January 11, 2019 Share Posted January 11, 2019 Hi. Sorry for the basic question! My TD5 110 hicap has always sat a bit low on the passenger side, but I put that down to old springs. I’ve just spent the afternoon fitting new springs and shocks all round but it’s still sitting 30mm low on the front passenger side.... and it looks horrible! The springs I’ve fitted are: nrc9449 Front left nrc9448 Front right rbk101111 rear springs rrc3266 rear helper springs I’m pretty sure they are the correct parts but do they really sit 30mm different side to side?! Quote Link to comment Share on other sites More sharing options...
western Posted January 11, 2019 Share Posted January 11, 2019 You can match the part numbers to those listed on here by Red90 sometime ago http://www.red90.ca/rovers/springinfo.html the fronts shouldn't be more than 10 to 12mm difference & rears should be the same length on both sides. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 11, 2019 Share Posted January 11, 2019 Have you put the front springs on the correct side. They are different so may be worth swapping them over. Mike Quote Link to comment Share on other sites More sharing options...
broken90 Posted January 11, 2019 Author Share Posted January 11, 2019 (edited) Hi. Thanks for the replies. The springs are in the right way (presuming that ‘drivers side’ is applicable for RHD and LHD!) Ive been and measured between the top and bottom spring seats and they are both the same. I notice in the link above that the spring lengths are different but the rating is the same... so maybe an easy fix is to swap them around. I’m a bit concerned there’s an issue elsewhere, the left hand front wheel/steering has been a bit strange for a while and I’m working through issues trying to trace it. Thanks for your help! Edited January 11, 2019 by broken90 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 11, 2019 Share Posted January 11, 2019 Perhaps the bodywork isn't lined up right, or you have a collapsed wheel bearing or swivel bearing? Does the wheel lean when straight ahead as well? Quote Link to comment Share on other sites More sharing options...
broken90 Posted January 11, 2019 Author Share Posted January 11, 2019 I don’t think the wheel is leaning, I’ll have to check properly in the light, I gave the wheel a good wobble and it seemed ok but I think that’s the next thing to get checked Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 11, 2019 Share Posted January 11, 2019 Jack the wheel up to wobble it. I had a swivel bearing go a few years ago and you couldn't tell till I jacked it up. Mike Quote Link to comment Share on other sites More sharing options...
