CR88 Posted February 26, 2019 Share Posted February 26, 2019 Hello all, My LR after running for a while in highway lost clutch pressure, and difficult or even impossible to engage/disengage any gear. This issue is making me crazy for a while, because, both master, slave cylinder and even the circuit are all new. This malfunction appears after running for a while, but in normal roads it doesn't happen. After some time and after pumping the clutch it eventually works again. ALL points to air/leak in the hydraulic circuit but it was redone for the 2nd time already... Any idea? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted February 26, 2019 Share Posted February 26, 2019 Exhaust heat boiling the clutch fluid perhaps? 1 Quote Link to comment Share on other sites More sharing options...
Ex Member Posted February 26, 2019 Share Posted February 26, 2019 What engine and gearbox. Is the heat shield in place for the clutch slave? 1 Quote Link to comment Share on other sites More sharing options...
CR88 Posted February 26, 2019 Author Share Posted February 26, 2019 It makes sense. 200 tdi + lt77 short bellhousing Anyone in the forum had a similar problem? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted February 27, 2019 Share Posted February 27, 2019 Do you have the heat shield in place next to the clutch slave? The exhaust runs very close. Item 19. Quote Link to comment Share on other sites More sharing options...
Escape Posted February 27, 2019 Share Posted February 27, 2019 I had similar with a Range Rover P38 manual. As long as you used the clutch, it was fine. But after doing some distance on the highway, it felt like there was air in the system and the pedal needed pumping before the clutch would fully disengage. Heat from the exhaust sounds like a very probable explanation. As repeated bleeding didn't work (not for long at least), I carried on like that for some time. By accident, I found a solution: I didn't tighten the cap from the reservoir fully at some point, and that solved the issue. I can only assume the improved venting was enough to prevent air from accumulation in the system. Filip Quote Link to comment Share on other sites More sharing options...
CR88 Posted February 27, 2019 Author Share Posted February 27, 2019 10 hours ago, Red90 said: Do you have the heat shield in place next to the clutch slave? The exhaust runs very close. Item 19. no, no protection at all exhaust wrap may help. What do you think? Thanks Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted February 27, 2019 Share Posted February 27, 2019 I have no heat shield on mine and occasionally after a long motorway run the first few clutch presses will be a bit 'spongy'. I think this is due to the fluid being old and the air boiling in it as above. Flushing the fluid for fresh stuff would help I am sure. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted February 27, 2019 Share Posted February 27, 2019 I assume you mean the water boiling. I assumed a flush is not needed as he states the slave and master are new. Just put on a heat shield. Exhaust wrap will rot the pipe, but you could try it for a test. Quote Link to comment Share on other sites More sharing options...
CR88 Posted March 1, 2019 Author Share Posted March 1, 2019 Hi, I'm going for the exhaust wrap just between the turbo and the slave cylinder. A heat shield is an option as well and easy to fit as well. Let's see how it works. Quote Link to comment Share on other sites More sharing options...
CR88 Posted June 1, 2019 Author Share Posted June 1, 2019 Hello all, Problem solved. Al heat shield just in the bottom (similar to the part 19 in the picture above), heat sleeve for the clutch pipes, and competition brake fluid (in this case Castrol SRF, but there are many others and cheaper). Thanks for your feedback and help. 2 Quote Link to comment Share on other sites More sharing options...
