Steering column shaft
Hi all , trucks a 110 200tdi , I was replacing the uj’s on the steering shaft this morning as I had some movement in it and thought the top uj had gone . I was taping the new one on the shaft gently and the shaft parted into its two halves , is this normal or is the shaft buggered ? Luckily I had the one off the 90 which I hadn’t fitted yet so put that one on the 110 as I need it for work . It seemed to come apart very easy so I’m starting to wonder if there was some movement in the shaft .
And if it is buggered and I need a new one can you upgrade it to one of the latter shafts off a td5 or  tdci of are they weaker or not as good as the ones off a 200/300 tdi ?
Any help much appreciated cheers Ian
Cheers James , it was how easy it came apart that was worrying not that it came apart I gathered that they were meant to come apart but didn’t think it should do that easy . Unless I was taping it in just the right place , I’ll knock it back together and see how it feels then .
