ianmayco68 Posted March 7, 2019 Share Posted March 7, 2019 Hi all , trucks a 110 200tdi , I was replacing the uj’s on the steering shaft this morning as I had some movement in it and thought the top uj had gone . I was taping the new one on the shaft gently and the shaft parted into its two halves , is this normal or is the shaft buggered ? Luckily I had the one off the 90 which I hadn’t fitted yet so put that one on the 110 as I need it for work . It seemed to come apart very easy so I’m starting to wonder if there was some movement in the shaft . And if it is buggered and I need a new one can you upgrade it to one of the latter shafts off a td5 or tdci of are they weaker or not as good as the ones off a 200/300 tdi ? Any help much appreciated cheers Ian Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 7, 2019 Share Posted March 7, 2019 They are designed to come apart in the event of a frontal impact, so are of a sliding design. If knocked the 'wrong' way then they will seperate. You should be able to put it back together. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted March 7, 2019 Author Share Posted March 7, 2019 Cheers James , it was how easy it came apart that was worrying not that it came apart I gathered that they were meant to come apart but didn’t think it should do that easy . Unless I was taping it in just the right place , I’ll knock it back together and see how it feels then . Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 7, 2019 Share Posted March 7, 2019 I've done that before on other vehicles, no harm done as long as it goes back together. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted March 7, 2019 Author Share Posted March 7, 2019 Cheers will tap it back together at the weekend. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted March 7, 2019 Share Posted March 7, 2019 Easily done. Pull it back together with a G clamp. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted March 8, 2019 Author Share Posted March 8, 2019 Cheers all put it back together today and all seems fine , so can fit it to the 90 now . 1 Quote Link to comment Share on other sites More sharing options...
