Gremlin Posted April 28, 2019 Share Posted April 28, 2019 Hi All I am at the moment refurbing a Husky winch. While its apart i thought it might be a good idea to fit new brushes to the motor. Now i have the parts manual and been trough the parts suppliers and no one seems to list the brushes separately (unlike other makes). Does anyone know if you can find replacements? or have the specs (lenght) of what they should be as new? Motor used to work when tested, not under load, loads and loads of black dust inside (brushes?) no corrosion or water ingress damage. Tips and advise welcome. Regards Grem Quote Link to comment Share on other sites More sharing options...
western Posted April 28, 2019 Share Posted April 28, 2019 Try https://www.firstfour.co.uk/ they do a lots of Husky parts, Superwinchin Tavistock [the UK factory] has closed according to recent reports of auctions clearing stock. Quote Link to comment Share on other sites More sharing options...
Gremlin Posted April 28, 2019 Author Share Posted April 28, 2019 Hi western, Thanks for the reply, pity they closed! yes i have been on the first four site, but no brushes listed. I am ordering some gaskets and other bits, will try asking maybe they know. Grem Quote Link to comment Share on other sites More sharing options...
Gremlin Posted April 28, 2019 Author Share Posted April 28, 2019 Another question, will one shot swivel grease work in the spur gearbox? G Quote Link to comment Share on other sites More sharing options...
western Posted April 28, 2019 Share Posted April 28, 2019 The grease I used came with my new motor, but firstfour do supply it this https://www.firstfour.co.uk/superwinch-husky-spur-gearbox-oil-250mm-pouch.html & worm gearvdrive gearbox https://www.firstfour.co.uk/superwinch-husky-worm-gearbox-oil.html I'm sure they will be able to advise on a suitable fluid grease Quote Link to comment Share on other sites More sharing options...
Gremlin Posted April 29, 2019 Author Share Posted April 29, 2019 Hi Western thanks again, in fact i will source the lubricants locally as its not worth having them sent over here. Just sent a mail to first four now we see their reply. G Quote Link to comment Share on other sites More sharing options...
Arjan Posted April 29, 2019 Share Posted April 29, 2019 Please note the Husky requires a special grade oil - stick to it. The gearbox / wormwheel needs that to work correctly.. First Four usu. has the correct stuff. Quote Link to comment Share on other sites More sharing options...
Gremlin Posted April 29, 2019 Author Share Posted April 29, 2019 Yes i will, no problem, but will buy locally. G Quote Link to comment Share on other sites More sharing options...
Gremlin Posted April 30, 2019 Author Share Posted April 30, 2019 Right some useful info for those who wish to keep thier Husky winch alive. The original motor is made by ISKRA - 11.216.273 AMJ4761 MAHLE Letrika (Iskra) DC motor A bit of history about Iskra, in 2012, the Slovenian auto electrical company Iskra Avtoelektrika changed its brand name to Letrika. There continuous product development earned the recognition of the profession. Letrika is a member of the MAHLE group since 2014 and use MAHLE Letrika brand name since 2015 and are now branded MAHLE. Specifications Voltage 12V Kilowatt 1.6kW Rotation from D/End CW/CCW C-C Mounts 90mm Mount Flange Diameter Case Mount ID 98mm Case OD 112mm Overall Length 227mm Case to End Shaft 60mm Shaft Outer Diameter 15mm Shaft Type MALE 20 SPLINE RPM 2800 Electrical Configuration F2/F1/A Ground NEGATIVE Operation Time F1/F2/A Weight (Kg) 6.7kg You can buy the brushes and other motor parts, although difficult they are available as these motors are run in all sort of configurations and applications. Pos. Letrika P/N MAHLE P/N Description 4 16.360.718 MMX 529 Armature 5 16.905.163 MMX 913 Bearing 7 16.908.017 MMX 739 Bolt 8 16.280.716 MMX 522 Stator 11 16.905.677 MMX 351 Set of brushes 13 16.908.018 MMX 941 Rear-end bracket 15 16.906.290 MMX 187 Protecting cover As regards to lubricants. Spur box is EP00 Grease, take your pick on the brand. Main box is 140SAE gear oil. Hope many will find this useful for maintenance Regards Grem 2 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 30, 2019 Share Posted April 30, 2019 Excellent information, and well found, thank you! Quote Link to comment Share on other sites More sharing options...
western Posted April 30, 2019 Share Posted April 30, 2019 Nice one Gremlin, I'll link it to the Tech Archive Winches section later. Quote Link to comment Share on other sites More sharing options...
Gremlin Posted April 30, 2019 Author Share Posted April 30, 2019 Thanks guys, Just ordered a fresh set of brushes (https://www.al-electric.de/), as mine were quite worn, next i will lightly skim the commutator so it has a fresh face. Motor should be like new when done. Just need to deciede what colour to repaint the winch........ original red or black............. G Quote Link to comment Share on other sites More sharing options...
Gremlin Posted May 8, 2019 Author Share Posted May 8, 2019 Brushes in house.............. 1 Quote Link to comment Share on other sites More sharing options...
Gremlin Posted May 15, 2019 Author Share Posted May 15, 2019 Last update before reassembly cleaned up commutator, and old vs new brushes Quote Link to comment Share on other sites More sharing options...
Gremlin Posted May 15, 2019 Author Share Posted May 15, 2019 Ah husky colour (by accident) is now in tones of grey................. Quote Link to comment Share on other sites More sharing options...
