CB Aerial Mounting, SIII Rag Top?.
SWB
  • 2 weeks later...
Sorry for the late reply, where Boris has is or on the front bumper, if it was a truck cab I would have said on the back of the cab on the gutter but you can more or less fit them anywhere even on ally but will need an earth wire running from the mount to a bolt that's going through something steel :)
  • 2 weeks later...
I have seen a piece of aluminium angle used on a series 2 windscreen mounting bolt used to mount an antenna. You could even mount it on one of the front wings using the hole where wing mirrors were once regularly mounted.
  • Like 1
  • 2 weeks later...
