Green200tdi Posted June 5, 2019 Share Posted June 5, 2019 As you know I’m fitting a td5 loom in my old110 its near finished only question I have is where do the reverse light and transfer box light go in to I have two possibles one grey plug under bonnet or two part of the harness where the ecu would plug in too I don’t have a engine loom but must end up in one of these connectors so grey plug ? or ecu plug ? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 5, 2019 Share Posted June 5, 2019 Full wiring diagrams with connector numbers & photos of every single connector are in the RAVE manuals if that helps. Quote Link to comment Share on other sites More sharing options...
MR-HIPPO Posted June 5, 2019 Share Posted June 5, 2019 (edited) You should have all the information in the TD5 wiring Diagram & Electrical reference, I gave you links to these in my post in your "green box" thread. Save those documents, they should be very useful. On 5/28/2019 at 8:30 PM, MR-HIPPO said: Not sure if you have these documents already or not, but the 2002 electrical circuit diagrams used alongside the 2002 Electrical library should be of use to you. Hope this Helps, Hippo. Edited June 5, 2019 by MR-HIPPO Quote Link to comment Share on other sites More sharing options...
western Posted June 5, 2019 Share Posted June 5, 2019 difflock wire is black/blue trace & reverse light wires are plain green & green/brown same as the old original loom. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted June 5, 2019 Author Share Posted June 5, 2019 (edited) Orange plug 😂 Edited June 5, 2019 by Green200tdi Quote Link to comment Share on other sites More sharing options...
MR-HIPPO Posted June 5, 2019 Share Posted June 5, 2019 What year is the loom? According to the 2002MY documents (linked above) Difflock is Black / Blue as Western said above. Reverse light wires are Light Green / Purple, from fuse 14 to feed Reversing switch on the gearbox, and green / Brown back into the loom on route to the dash lamp. All of these wires go through connector C0448, (Engine loom plug) Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted June 5, 2019 Author Share Posted June 5, 2019 10 minutes ago, MR-HIPPO said: What year is the loom? According to the 2002MY documents (linked above) Difflock is Black / Blue as Western said above. Reverse light wires are Light Green / Purple, from fuse 14 to feed Reversing switch on the gearbox, and green / Brown back into the loom on route to the dash lamp. All of these wires go through connector C0448, (Engine loom plug) It’s from a 2005 vehicle Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted June 5, 2019 Author Share Posted June 5, 2019 So basically two wires from reverse light switch end up at the gray plug along with transfer box light? Quote Link to comment Share on other sites More sharing options...
MR-HIPPO Posted June 5, 2019 Share Posted June 5, 2019 (edited) Yes. Looks like pins 3, 4 and 5. The Wiring Diagrams / Electrical reference library really are invaluable. Edited June 5, 2019 by MR-HIPPO Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted June 5, 2019 Author Share Posted June 5, 2019 Brilliant that was all I wanted to know as it’s the last thing on the list engine loom I’ll do that when engine back in 😂 Quote Link to comment Share on other sites More sharing options...
