trickydicky Posted June 22, 2019 Share Posted June 22, 2019 hi iv got a 200tdi defender that has the timing belt riding forward .its a 1990 engine its done about 200,000 miles .when I first had it I changed the belt and the original belt had been wearing on the case .since then iv had no problems .I changed the belt for a trip around the highlands .and since then the problems come back . iv used the correct tools to tention the belt and the belt was a daco kit has anybody got any imfo on why this is happening and how to cure it . Quote Link to comment Share on other sites More sharing options...
MR-HIPPO Posted June 22, 2019 Share Posted June 22, 2019 @Mo Murphy Had a similar problem, it is discussed here. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted June 23, 2019 Author Share Posted June 23, 2019 thanks for that mr hippo ill let you know what happens Quote Link to comment Share on other sites More sharing options...
trickydicky Posted June 29, 2019 Author Share Posted June 29, 2019 this morning I took my cambelt off to find out what exactly was causing it to ride forward .all the pulleys seemed fine until a came to fit the new belt .then I noticed the pump pulley main bolt had worked loose so the pulley could move forward when ever it felt like it .all sorted now thanks for your help. 1 Quote Link to comment Share on other sites More sharing options...
MR-HIPPO Posted June 29, 2019 Share Posted June 29, 2019 Thanks for the update. Glad you got it sorted. Quote Link to comment Share on other sites More sharing options...
western Posted June 29, 2019 Share Posted June 29, 2019 Good you found the cause. Quote Link to comment Share on other sites More sharing options...
