JimAttrill Posted August 22, 2019 Share Posted August 22, 2019 The spring I removed has a free length of 47.5mm. The official LR manual says it should be 68mm. This can't be right. Is the one at 47.5 length OK? Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted August 22, 2019 Share Posted August 22, 2019 My data states 68mm too. 20mm shrink is probably to be expected after min of 20 years use. I would be getting a new spring and plunger to be safe. Quote Link to comment Share on other sites More sharing options...
western Posted August 22, 2019 Share Posted August 22, 2019 Photo on here might help https://www.brit-car.co.uk/product.php/84590/1189/relief_valve_spring_300tdi Quote Link to comment Share on other sites More sharing options...
western Posted August 22, 2019 Share Posted August 22, 2019 200Tdi relief valve spring is closer to 68mm long https://www.brit-car.co.uk/product.php/95679/0/oil_pressure_relief_spring_2_25_200_300tdi___series_111___defender___discovery_1___range_rover_classic Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted August 22, 2019 Share Posted August 22, 2019 2 minutes ago, western said: 200Tdi relief valve spring is closer to 68mm long https://www.brit-car.co.uk/product.php/95679/0/oil_pressure_relief_spring_2_25_200_300tdi___series_111___defender___discovery_1___range_rover_classic That's interesting as its a landrover 300tdi rebuild manual that states 68mm. In pic it does look like the 300 is about 55mm Quote Link to comment Share on other sites More sharing options...
western Posted August 22, 2019 Share Posted August 22, 2019 My manual says 67.82mm for free length of 200tdi spring. so nominal 68mm is close enough. Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted August 23, 2019 Share Posted August 23, 2019 (edited) Mine had shrunk by a similar amount to the OP's, so it does happen. The workshop manual says the plunger should be changed with the spring. I don't think the engine rebuild manual is so prescriptive, and I can't see why it's necessary. Edited August 23, 2019 by nickwilliams Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted August 30, 2019 Author Share Posted August 30, 2019 I fitted a new spring and plunger. The spring was 55mm. Quote Link to comment Share on other sites More sharing options...
