kaijun Posted September 22, 2019 Share Posted September 22, 2019 When I changed rear axle oil yesterday, I found its wet, then looked up forward a bit, there is a wet area where the rear seat is located above. I guess it could be leak from a fuel line (HP line?). But I can not see any fuel line at this location, maybe it is hidden between the inside floor and bottom of the car. How do I get access from the above of the wet area? Any ideas are appreciated! Quote Link to comment Share on other sites More sharing options...
steve b Posted September 22, 2019 Share Posted September 22, 2019 Most likely the return line chafed through between top of tank and floor/chassis , tank out to fix it usually . cheers Steve b Quote Link to comment Share on other sites More sharing options...
kaijun Posted September 22, 2019 Author Share Posted September 22, 2019 I also suspect a line is chafed, but it is not above the tank which is half dry at the left of the picture. I don’t know if there is access to the line above a piece of metal plate secured by the four bolts or from under the car carpet. Quote Link to comment Share on other sites More sharing options...
bear Posted September 24, 2019 Share Posted September 24, 2019 Hi, The high pressure pipe is called "the green pipe" if you want to google it. It can be bought seperatley. It connects above the o/s chassis to the pipe to the engine and to the top of the fuel pump. You do need to remove the cover plate in the boot to access the top of the tank. It is possible to replace it by tying string to the old pipe as you pull it out and then pulling the new pipe through. It runs above the chassis which is why you can't see it above the tank. Make sure you put some sort of protection around the new pipe to stop it happening again. This gives you a layout of the pipes http://new.lrcat.com/#!/1232/38332/38387/2961 HTH, Griff Quote Link to comment Share on other sites More sharing options...
kaijun Posted September 24, 2019 Author Share Posted September 24, 2019 (edited) Thank you for your info, Griff. Is the pipe connector to the engine direction accessible? Edited September 24, 2019 by kaijun Quote Link to comment Share on other sites More sharing options...
bear Posted September 29, 2019 Share Posted September 29, 2019 Yes, but it's on top of the o/s chassis rail. Griff Quote Link to comment Share on other sites More sharing options...
kaijun Posted September 29, 2019 Author Share Posted September 29, 2019 22 minutes ago, bear said: Yes, but it's on top of the o/s chassis rail. Griff I checked the wet area again this weekend. it is dry or half dry around it, apart of that it has no drips. I checked the tank and fuel pipe lines on chassis which is lower than the wet area. They are dry too. It seems a fluid was gushed from its underneath. I saw there are two grease U-turn hoses, last year MOT mentioned (Offside Rear Brake pipe corroded, covered in grease or other material to hose) I don't think they are brake pipe but connected ACE pipes (see pic). However ACE level is still at max. I saw the rear axle oil was low when I changed it last week, gushed from there? or from the breather of tank if the tank was refilled fully some day. It is mysterious to me Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted September 29, 2019 Share Posted September 29, 2019 only time ive seen this is when pinion seal has failed and diff oil is flung up when rotating. Quote Link to comment Share on other sites More sharing options...
kaijun Posted September 29, 2019 Author Share Posted September 29, 2019 You are probably right. I found a leak between rear shaft and rear hub, It could be o ring leak. Wonder anyone fixed rear axle leak? Quote Link to comment Share on other sites More sharing options...
bear Posted September 30, 2019 Share Posted September 30, 2019 You can see the rear hub O ring here (Item 2) http://new.lrcat.com/#!/1232/35470/35681/2704 They are easy to change -just fit in a groove on the rear of the hub. However, tried replacing 2 on mine but needed a new hub in the end. Worth a try though as they're cheap enough. Griff Quote Link to comment Share on other sites More sharing options...
kaijun Posted September 30, 2019 Author Share Posted September 30, 2019 Sorry for wrong description. The leak happens between diff unit and propeller shaft. See Between 9 and 10 of attached picture. Quote Link to comment Share on other sites More sharing options...
