liams105e 0 Posted October 31 Hi, I've got a manual 300tdi disco. The speedo stopped working the other day, but then half way through my journey it just picked back up and continued fine. It's done this a couple more times now. Any ideas what component is at fault? Cheers. Quote Share this post Link to post Share on other sites
Richard Mills 3 Posted October 31 Check the alternator connections, the speedo is fed from there, it will be corrosion on the tag of one of the smaller spade terminals, or just plain loose. Quote Share this post Link to post Share on other sites
FridgeFreezer 1,138 Posted October 31 13 minutes ago, Richard Mills said: Check the alternator connections, the speedo is fed from there, it will be corrosion on the tag of one of the smaller spade terminals, or just plain loose. Sorry, that's rev counter, the speedo is mechanically driven off the transfer box along a flexible drive cable. Cables can fret, or work loose. Quote Share this post Link to post Share on other sites
finnarne 6 Posted November 1 Nn the 300tdi I have seen, there is a transducer that are mounted on the transfer box, with 3 pin connector. So the speedo is in fact electrical driven. Check the transducer for wear, I have a couple in my garage (on the floor somewhere) that are half way broken. http://new.lrcat.com/#!/1231/27317/27318/2046 part number AMR1253, replaced it seems by YBE100540 Quote Share this post Link to post Share on other sites
liams105e 0 Posted November 3 Thanks for the advice, i'll start with replacing the transducer, and take it from there. Quote Share this post Link to post Share on other sites
