hallio Posted November 1, 2019 Share Posted November 1, 2019 Hi I have a Land Rover 101 with a RR 3.9 EFi in it (not my conversion, it's the way i got it) so I'm posting this question here as it's an engine issue I'm experiencing. The vehicle ran fine a week ago when I parked it up and went out today to use it and it won't start. It spins over nicely so first I checked i'm getting spark by holding the HT coil lead to ground (nice spark) and put a plug tester into one of the plug leads (nice bright light). A squirt of easy start will let it run for a second or two so I assume the ignition is OK and therefore it's a fuel issue. Previously you could hear the pump prime for a few seconds when the ignition was turned on and now I don't hear that. The pump works fine when I hook up a +12v to it, but when the I try to start it with this +12v connected it still won't run, so something is telling the engine that it shouldn't go. Just to confuse matters after a bit of prodding and poking it did run again, so I let it run while I started packing up my tools and then after a minute or two the engine stalled / died and hasn't started since. I'm wondering what simple diagnostic steps I can take to get this sorted, or at least get a little closer to finding the problem. My main issue is that this is a non-standard engine for this vehicle and has been DIY installed and hence any wiring diagrams may not reflect reality! Thanks all Steve H Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 2, 2019 Share Posted November 2, 2019 Sounds to me like the fuel pump may have simply failed. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 2, 2019 Share Posted November 2, 2019 First question is did you buy the 101 down south from a chap called Martin? To the problem at hand - if the pump runs with 12v on it then hopefully it's OK (although rarely they can go weak yet still run), so I'd check if power is getting through to it and if not, where it stops. 1st stop is to check you're getting power on the brown wire into the fuel pump relay. After that, you can jumper out the fuel pump relay to prove it - jumper the brown wire to the white/purple to run the pump permanently (while chasing the fault), and you can check for 12v / gnd out of the ECU across the white/slate and blue/purple pair, there should be 12v across this when the ECU wants to run the pump (I can't remember if it switches the 12v side or the ground side, so be careful how you measure to avoid fooling yourself!). I've had the relays fail and you need to be aware that they're an odd type - 5-terminal with two ganged terminals, confusingly marked 87 and 87a even though that disagrees with how VWP list them; R30BT- 5 blade twin make & break. Similar to R20BC, but with two blades at 87 feed. Here's the 3.9 V8 system diagram for you, hopefully it's just been transplanted over to your 101: Quote Link to comment Share on other sites More sharing options...
hallio Posted November 2, 2019 Author Share Posted November 2, 2019 Thanks. I'm pretty sure the pump is ok and to my mind the main symptom here is it's not running when I turn the ignition on whereas it always used to. My tests this morning have narrowed it down to what I think is the ECU - it'd be good if you could confirm my diagnosis. With the ignition on I'm not getting 12v on the 87 terminals on either the main relay or fuel pump relay (unlikely both relays failed at the same time). I then confirmed the ECU is getting 12v on the correct connectors when ignition is off and on. With the ECU connector removed I grounded the 'switch' terminal on the main relay and did then get 12v on the 87 terminal. This to my mind means the ECU is not switching on the relays? In addition I hooked up my laptop with RoverGauge to the ECU and it said it couldn't communicate with the ECU (it worked last time I used it). Thanks Steve P.S The 101 came from a guy called Dave in Bristol! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 2, 2019 Share Posted November 2, 2019 You've checked the ECU has +12v but is it well grounded? There's a full EFI troubleshooting guide in the technical archive section. Quote Link to comment Share on other sites More sharing options...
hallio Posted November 2, 2019 Author Share Posted November 2, 2019 (edited) Good point, I'll double check the earth tomorrow. It looks like Pin 4 on the diagram above (and mine here) and yes I've been working through the troubleshooting manual. I've been looking on eBay for second hand ECUs and there seems to be a myriad of different part numbers for the 14CUX - does it really matter which I use in this case (mine is PRC9061/80274B) or are they pretty interchangeable? i.e choose a RR / Disco 3.9 from the same year (ish) and it should be OK? Thanks for the help. Edited November 2, 2019 by hallio Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 2, 2019 Share Posted November 2, 2019 There's quite a few earths come out of the plug, bear in mind all the current for the fuel injectors etc. is grounded though the ECU even though the 12v side is supplied through the external relay. I doubt the ECU is faulty, they're not really prone to failure - most faults are wiring or a sensor or such like. Also, it would be remiss of me to get this far down an EFi trouble thread without suggesting you fit Megasquirt in its place Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 2, 2019 Share Posted November 2, 2019 On 11/1/2019 at 3:03 PM, hallio said: The pump works fine when I hook up a +12v to it, but when the I try to start it with this +12v connected it still won't run, so something is telling the engine that it shouldn't go. Just to confuse matters after a bit of prodding and poking it did run again, so I let it run while I started packing up my tools and then after a minute or two the engine stalled / died and hasn't started since. This was the bit that suggested to me that the pump was on its last legs. all the other suggestions are good of course Quote Link to comment Share on other sites More sharing options...
hallio Posted November 2, 2019 Author Share Posted November 2, 2019 Thanks. I have a spare pump so may just drop that in for the purposes of elimination. My thinking it was the ECU was because both main and pump relay don't switch on when connected to the ECU (but do seem to be working) and in addition my RoverGauge can't read from the ECU when previously it could? I'll go over all the earths though and cleanup all the relay contacts etc though next, seems a sensible move. TBH MegaSquirt probably isn't really worth the effort - I barely do any miles in this vehicle and it's cost me enough to get it this far! I thought all my problems were over when I parked it up a week or to ago after spending most of this year getting it up and running again! (I should know better than that with old Land Rovers). Cheers Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 3, 2019 Share Posted November 3, 2019 The ECU may not switch the pump on until it decides it needs to - usually that's once it sees some pulses from the coil -ve although I don't know if the hotwire system primes the pump? If you're certain it WAS doing it before and isn't now, by all means suspect the ECU... but if you're not sure, I'd wager it's just not choosing to run it until it needs it. As Bowie says, could be a weak pump or could be the fuel pressure regulator has given up the ghost. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 3, 2019 Share Posted November 3, 2019 Hotwire does indeed prime the pump, and yes it does wait for spark before running the pump after the initial prime. Quote Link to comment Share on other sites More sharing options...
hallio Posted November 3, 2019 Author Share Posted November 3, 2019 After more digging it looks like it may be the main ECU relays on the blink - the fuel pump relay is actually OK, however I suspect nothing will work if that main relay isn't working. Certainly an easier (cheaper!) thing to try before the ECU anyway 🙂 Thanks all. 1 Quote Link to comment Share on other sites More sharing options...
hallio Posted November 3, 2019 Author Share Posted November 3, 2019 Yup, was the main relay. Nipped out and grabbed another one today and and all is good again 🙂 Thanks for the help. Steve 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 3, 2019 Share Posted November 3, 2019 Glad you're sorted! Quote Link to comment Share on other sites More sharing options...
Doolo Posted September 4, 2023 Share Posted September 4, 2023 Anyone help me decide , i m having this issue , intermittently , i have a volt guage on the fuel pump and it supposed to prime on ignition ( 2s) and then wait till engine on , signal then rerun to fuel pump again again .( theres a lift and high pressure pump , its the HP prump Im refering to . Walked 10 km yesterday and had to be towed !!!! I have had in past lost fuel pump voltage and then she cuts out after starting ok, i used to have a separate battery ion cab ready to power the fuel pump directly . Would a main and fuel pump relay be a good idea to rule them out. I had a meter on them and wasnt seeing voltages to them last night so i didnt expect them to work battery to ecu-inertia sensor ( if i can find one) to relay to injector fuel pump. Pu,p seems ok on bench and when it has power she dives fine. Yesterday as i braked hard and did a swerve to avoid a cyclist the fuel voltage disappeared , i can no longer get it started. Can anyone confirm ( transplanted into a 199 series 2 , 3.9 efi) where i might find an inertia sensor which on diagram is there to cut fuel in case of accident i gues >? Adrian Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 4, 2023 Share Posted September 4, 2023 Adrian, Without knowing what has been done with your particular conversion it's hard to be certain what the fault could be - bearing in mind the ECU will switch the fuel pump OFF if it thinks the engine has stopped (not seeing pulses from the coil -ve and not seeing airflow on the AFM) so bear that in mind - it's easy enough to see if the ECU is powering the relay or not with a simple LED wired to the ECU-side of the relay. As a start I would try following the fuel pump wiring from the fuel pump itself through the loom, relay, and into the ECU pin to see if there's anything obvious. Fundamentally you've only got a few things that can fail; Wiring harness (EG a bad joint or broken wire) Relay and power feed to it Signal from ECU Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted September 4, 2023 Share Posted September 4, 2023 The inertia switch is under the driver's seat in a range rover - but it's anyone's guess where (or even if) it is on your truck. I'd be very surprised if you'd trigger it just by violent manoeuvring, though, unless it's flapping around somewhere not properly mounted. Quote Link to comment Share on other sites More sharing options...
Doolo Posted September 5, 2023 Share Posted September 5, 2023 Thanks to both for help , last night i proved both relays are clicking and passing power from term 30 to outputs 87 and 87 on bench , so Im back before relay in the hunt again where im not seeing voltages i used to , lift pump humms away , ignition light etc fine , so some things are getting power , its pull harness out where i can and walk my way back to the ECU.ECU is v acessible but its like like going to a funeral and unable to look at the body , i fell added sadness will come over me once i look at ECU & accept the fact its never comming back , maybe the ECU is the root tormenting me all along but the intermittent nature is wierd - dry joint inside ECU didnt like the bump ??. I have a feeling 'never smart with old vehicles' that some thing is loose , like as if the earth that the fuel pump looses its grounding . i did find an earth looking wire ( conversion person used some home earth wires colour coding in a loom headed to ward he altenator - i hear you all sighning and turning the page now) So before i go looking for a loaner ECU anyone know where the main earths that the ECU/fuel pump high press ure might join the chassis as this might be loose and explain the loss of 12v to the fuel pump while driving along.IT wont stadt now as its still missing voltage , i apply manual 12v and that no longer ools it . Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 5, 2023 Share Posted September 5, 2023 So you say the relays click and deliver 12v where they should - does that mean they click if you test them but the ECU is not engaging them, or does that mean the ECU engages them & they click but stuff still doesn't work? A few photos of the main points of your wiring loom & fuel pump setup might help give us a few clues. Also highly unlikely the ECU has gone faulty, far more likely bad wiring or a dodgy sensor/signal - always look at the cheap & easy stuff first! On the 3.9 the ignition amplifier on the dizzy like to fail for a pastime - that would stop everything. 1 Quote Link to comment Share on other sites More sharing options...
