New exhaust manifold
Snowbird
Its probably to provide for expansion - which can cause manifolds to crack.  This is why many manifold fixings (like 2 inner combined ones on the LR 4 cylinder petrol) are lugs cast into the manifold and cast steel clamps to secure the manifold - and allow it to expand and contract.
If its a petrol the register of the manifold on the head is controlled by dowels - and the exhaust is rigidly fixd to the inlet at the centre - form which it will expand outwards.
When re-fixing used manifolds its always a good idea to make sure that the movement isn't restricted by rust in the bolt holes - ie clean them out thoroughly.
Thanks guys for the info, you guessed right it's a series 3 petrol. Will get some large thick washers to put on those 4 mounts. The old one had normal 5/16 bolt holes and was a sod to get off and was cracked in numerous places. Will take pics Arjan and post.
