soutie Posted January 22, 2020 Share Posted January 22, 2020 I have an 1989 110 that had a factory conversion from TD to 200 Tdi and it used the oil cooler pipes ESR1912 / ESR1913. To replace these one needs to fork out about £110 to replace both of them. Instead of paying this price are there alternative part numbers to use - or should I get the hoses renewed by a hydraulic hose place? i.e. can I use PBP500190 or ESR3690 in place of ESR1912? Or do I have to suck it up and pay the going price? Quote Link to comment Share on other sites More sharing options...
western Posted January 23, 2020 Share Posted January 23, 2020 I replaced those pipes a while ago, I certainly didn't pay 100 quid each for them.I got both for 115 from my local LR independent parts place, this was 2 june 2018. just dug out the invoice for them. you cannot use the other hoses as the end fittings of the metal pipes are different & will not seal in the oil filter head. only way to fit the other curved end pipes is to obtain the matching filter head which is certainly not cheap. I don't think the RRC or Discovery pipes will fit. as the 200Tdi in a defender sit behind the front axle so the oil cooler hoses are longer. Quote Link to comment Share on other sites More sharing options...
andy _1 Posted January 23, 2020 Share Posted January 23, 2020 I have just done this, there is no pressure in the oil cooler lines. Cut off the existing crimps and get a hydraluic hose shope to lengthen the rubber pipes ,there is no flare on the pipes it's just a plain pipe. That's how the crimps are from the factory. Hers some pics I doing door pillar just now and the wings off Quote Link to comment Share on other sites More sharing options...
blowmeover Posted January 24, 2020 Share Posted January 24, 2020 I just used hydraulic hose, its been that way for 13 years now. Quote Link to comment Share on other sites More sharing options...
soutie Posted January 24, 2020 Author Share Posted January 24, 2020 Thanks for the feedback. I will clean up and pain the old metal bits and get new pipes fitted from a Hydraulic place. Question on the O rings. Are they a special material compared to o rings from a motor factor? Quote Link to comment Share on other sites More sharing options...
andy _1 Posted January 24, 2020 Share Posted January 24, 2020 No they are just o rings petrol / oil resistant buy yourself a set . I bought these from amazon . Quote Link to comment Share on other sites More sharing options...
