Mutley Posted February 23, 2020 Share Posted February 23, 2020 Looking at re-newing the manifold gasket on my 300Tdi, so how easy/hard a job is it and is there anything I kneed to know? Plus which gasket to use ie is this an always use original part or is a Bearmach item satisfactory? Part number I have is ERR3785 Cheers all Andy Quote Link to comment Share on other sites More sharing options...
western Posted February 23, 2020 Share Posted February 23, 2020 just remove all the manifold bolts/nuts, move manifold away from the block & remove the old gasket, clean the faces, fit the new gasket, on my 200tdi I always use Elring [OEM ] gaskets. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted February 23, 2020 Share Posted February 23, 2020 I always use elring gaskets as well. On the 300 there is a nut and stud hidden behind the turbo, my sockets fit through the gap to undo it but it's an utter swine to do. It could potentially be easier with a stubby spanner. Quote Link to comment Share on other sites More sharing options...
Mutley Posted February 23, 2020 Author Share Posted February 23, 2020 OK an Elring gasket it is then guys ad thanks for the heads up about possible awkward to get to nut Vulcan bomber. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted February 23, 2020 Share Posted February 23, 2020 If you have a 3/8" drive with short extension, you should be able to get in there. Quote Link to comment Share on other sites More sharing options...
Mutley Posted February 23, 2020 Author Share Posted February 23, 2020 @Peaklander.....The wife's got little hands and is only 4 foot and a dog end! Does that count!?! Quote Link to comment Share on other sites More sharing options...
Peaklander Posted February 23, 2020 Share Posted February 23, 2020 Yes send her in! Quote Link to comment Share on other sites More sharing options...
