Defender 200tdi Alternator pulley spacer
1 hour ago, Red90 said:
You understand that is just to spacer out the adjuster arm from the timing cover? It is not a critical dimension.  If you need one, they are 2 pounds new.
Looks like a pulley spacer to me and if you Google the part number that's what it says. It could be critical if you have alignment issues.
Mike
