Green200tdi Posted April 30, 2020 Share Posted April 30, 2020 Hello all hope your all doing well, just a quick question, on the TD5 15p loom does the radio get its permanent live from one of the fuses on the bulkhead fuse box if so what fuse? this is second time I’ve lost all my pri set stations🙄 For years on my other land rovers I’ve always had separate live to battery with in line fuse, Thank you, 😊 Quote Link to comment Share on other sites More sharing options...
crwoody Posted April 30, 2020 Share Posted April 30, 2020 (edited) The circuit diagram refers to the permanent live feed fuse as - "F30, Fuse box Satellite (P109)" so far as I can gather it's in the passenger compartment fuse box, in the single row on the left. The switched feed fuse is "F17, Fuse box passenger compartment (P101)" in the upper right row. It's also worth checking the common earth header on the bulkhead, behind the coolant expansion bottle, I've had them come loose before. https://www.lrworkshop.com/electrics/defender-2002my/fuse-boxes-earths-and-headers Edited April 30, 2020 by crwoody Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted April 30, 2020 Author Share Posted April 30, 2020 Ok thank you👍 its ok I don’t have a fuse board diagram so when my light was playing up I blew a fuse so had to pull each one individuals to locate side light Fuse, always the last fuse😂 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 1, 2020 Share Posted May 1, 2020 There are original Land Rover fuse board decals out there if you need replacements. Mo Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted May 3, 2020 Author Share Posted May 3, 2020 (edited) No just need to know what I was doing wrong, I thought the radio would be on a fuse in the fuse box under the driver’s seat as it was a permanent live but it’s ok as I don’t have td5 fuse layout card only other way is to pull one at a time hence I lost station memory’s, will sort one soon, new loom has been in since June last year and really can’t fault it been brilliant no hazards light switches blowing no glowing fuses really worth the up grade 👍 Edited May 3, 2020 by Green200tdi Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 3, 2020 Share Posted May 3, 2020 Have you had the radio out? Could be a loose write in there? Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted May 3, 2020 Author Share Posted May 3, 2020 No, it was due to pulling all the fuses as I found out the bottom row right hand is both side lights, always last fuse 😂 Quote Link to comment Share on other sites More sharing options...
