Jut Posted July 16, 2020 Share Posted July 16, 2020 at some point in the near future i'm going to have to fit a heavy duty clutch. so whilst the gearbox is out thought if possible would look at 1 - 2 syncro as not good at changing at high revs. before we start i know all about double clutching etc. just niggle i would like to fix. anybody stripped there gearbox R380. is it possible to change the just the 1 -2 syncro with out a complete strip down? many thanks Quote Link to comment Share on other sites More sharing options...
Snagger Posted July 16, 2020 Share Posted July 16, 2020 I suspect not, and it’s a job I’ll need to do (2nd rather than first grinding a little on quick changes, as is common). Britannica Restorations has a few YouTube videos on how to do it, with some of the traps to watch for. He also sells USB sticks with the manuals loaded on them, so the two together would be very useful. Quote Link to comment Share on other sites More sharing options...
andy _1 Posted July 16, 2020 Share Posted July 16, 2020 (edited) I not stripped a r380 but lt77 . The difference is from memory where 5 and reverse is. No it on the main shaft you could just replace 1 and 2 baulk rings but you might as well do the lot when your in there you'll have it in bits at that point anyway . Just seen post above just use the video from mike @britiana restorations that's what I used. Edited July 16, 2020 by andy _1 Quote Link to comment Share on other sites More sharing options...
Jut Posted July 17, 2020 Author Share Posted July 17, 2020 looks some video watching tonight with a friday pint... thanks Quote Link to comment Share on other sites More sharing options...
DaveSIIA Posted July 18, 2020 Share Posted July 18, 2020 From memory, 1 - 2 synchro rings of a R380 will require a full strip down & rebuild as they are on the mainshaft just forward of the centre plate. 3 - 4 are accessible at the front end with just the input shaft removed. 5th requires removal of the rear housing, etc. TBH, if in that far then a full overhaul is the way to go. Quote Link to comment Share on other sites More sharing options...
Jut Posted July 20, 2020 Author Share Posted July 20, 2020 On 7/18/2020 at 12:23 PM, DaveSIIA said: From memory, 1 - 2 synchro rings of a R380 will require a full strip down & rebuild as they are on the mainshaft just forward of the centre plate. 3 - 4 are accessible at the front end with just the input shaft removed. 5th requires removal of the rear housing, etc. TBH, if in that far then a full overhaul is the way to go. Looks like its ganna be a first time land rover gearbox strip.... Quote Link to comment Share on other sites More sharing options...
