kevin50 Posted August 27, 2020 Share Posted August 27, 2020 Got a few teething problems on my just finished rebuild. some I can put up wuth for now but would like to get this one sorted before winter. Just put brand new Matrix in, heaters work in a Fashion but only on this position on Vid. Also when the leaver is down on the Red it blows nice and hot, but when up in the Blue it still blows hottish/ warm. The far lever on the right works as it should, changing air from top of dash to bottom. Any Ideas of what I have done wrong ? Quote Link to comment Share on other sites More sharing options...
western Posted August 27, 2020 Share Posted August 27, 2020 Could be the cables need adjustment. Have read of this https://forums.lr4x4.com/topic/33481-feeling-the-cold-in-your-truck/ 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 27, 2020 Share Posted August 27, 2020 Yep. The temperature control lever moves a diverted flap inside the matrix housing that blocks the matrix when cold is selected, and blocks the bypass when full hot is selected, allowing air through both paths in proportional amounts in intermediate positions. It sounds like the cable is set so the door is not closing the hot path off. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted August 27, 2020 Author Share Posted August 27, 2020 2 hours ago, Snagger said: Yep. The temperature control lever moves a diverted flap inside the matrix housing that blocks the matrix when cold is selected, and blocks the bypass when full hot is selected, allowing air through both paths in proportional amounts in intermediate positions. It sounds like the cable is set so the door is not closing the hot path off. will have a look at cable. Would that cause the blower to work only in that one position ? Quote Link to comment Share on other sites More sharing options...
western Posted August 27, 2020 Share Posted August 27, 2020 watching your video, to me it looks like the slow speed resistor &/or the slider switch is not operating, could be a burnt out or disconnected resistor or a damage slider track. also recheck the wiring connections on the control switch & at the heterbox. I do have a fairly new left heater control part here that I would be willing to sell if you need it. Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 27, 2020 Share Posted August 27, 2020 39 minutes ago, kevin50 said: will have a look at cable. Would that cause the blower to work only in that one position ? No. That is completely independent. The blower motor switch is on the left lever which operates a three Position switch and the matrix housing flap that closes against the bulkhead to stop all ram airflow with the fan off. If the temperature lever is affecting the blower, the cable adjustment may be causing the doors/flaps to interfere with each other so the blocker door can only open (and thus the fan switch on) with the temperature flap out of the way. That interference should not occur, so something may be in the incorrect position within the housing. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted August 27, 2020 Author Share Posted August 27, 2020 2 hours ago, western said: watching your video, to me it looks like the slow speed resistor &/or the slider switch is not operating, could be a burnt out or disconnected resistor or a damage slider track. also recheck the wiring connections on the control switch & at the heterbox. I do have a fairly new left heater control part here that I would be willing to sell if you need it. Will take that lever off and check wiring. 2 hours ago, Snagger said: No. That is completely independent. The blower motor switch is on the left lever which operates a three Position switch and the matrix housing flap that closes against the bulkhead to stop all ram airflow with the fan off. If the temperature lever is affecting the blower, the cable adjustment may be causing the doors/flaps to interfere with each other so the blocker door can only open (and thus the fan switch on) with the temperature flap out of the way. That interference should not occur, so something may be in the incorrect position within the housing. When I fitted new matrix I checked the flap on the lever and it does work, ie opens and closes but was not quite closing fully, maybe half inch gap left when in fully closed position. Will open the lid and see if I can see without having to take matrix back out. Quote Link to comment Share on other sites More sharing options...
western Posted August 27, 2020 Share Posted August 27, 2020 No need to open the heater box, slacken the cable on top as in the link I added, Quote Link to comment Share on other sites More sharing options...
kevin50 Posted August 27, 2020 Author Share Posted August 27, 2020 35 minutes ago, western said: No need to open the heater box, slacken the cable on top as in the link I added, Thanks Do you mean the cable on the Lever or on the Box ? Quote Link to comment Share on other sites More sharing options...
western Posted August 27, 2020 Share Posted August 27, 2020 At the heater box end, all is explained in the link. Quote Link to comment Share on other sites More sharing options...
