Defender Posted August 27, 2020 Share Posted August 27, 2020 Quick question: If I want to put a V8 into a 300tdi Defender is the Short/Stumpy R380 the best route to go gearbox wise please? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted August 27, 2020 Share Posted August 27, 2020 You can't use the stumpy R380 - that bellhousing pattern only fits the 4-cylinder engines (e.g. 200Tdi/300Tdi). If you want to use an R380 you'll need one with a V8 bellhousing and input shaft. 2 Quote Link to comment Share on other sites More sharing options...
Boris113 Posted August 28, 2020 Share Posted August 28, 2020 I'm slowly accumulating parts to do the same, if you want to use a V8 spec R380 you need the one from a D1 or better yet a D2, the P38 version is very different. 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 28, 2020 Share Posted August 28, 2020 7 minutes ago, Boris113 said: if you want to use a V8 spec R380 you need the one from a D1 or better yet a D2, the P38 version is very different. ...and a shifter relocation kit from Ashcrofts I believe. Quote Link to comment Share on other sites More sharing options...
Defender Posted August 28, 2020 Author Share Posted August 28, 2020 Ok thanks for the help. Just to add another question what about the stumpy R380 with an LT77 to V8 conversion ring........ Will this be too short? I already have these components as they were bought for a 101 conversion but I sold the 101 before I did it. So really just trying to determine if I can reuse what I have or if I'm just making things difficult for my self. It would be great if I don't have to source more components. Quote Link to comment Share on other sites More sharing options...
