Green200tdi Posted November 18, 2020 Share Posted November 18, 2020 Need to get one of these plugs but need the technical name to look them up please Quote Link to comment Share on other sites More sharing options...
western Posted November 18, 2020 Share Posted November 18, 2020 PaulMc is your man, he knows lots about LR connectors. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 18, 2020 Share Posted November 18, 2020 Looks similar to a junior power timer, but as above @PaulMc is your connector man. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted November 19, 2020 Share Posted November 19, 2020 What's it for? Could you post some more pictures of it, from the front and rear. As said above, it looks like a Junior Timer / Junior Power Timer variant. But there are other makes that are similar, some interchangeable, some not. . Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted November 19, 2020 Author Share Posted November 19, 2020 It’s the front fog light on my Volvo one of them failed so though new bulb turns out the whole light had rotted away and pin broke off in this plug so got another light fitted it chopped of This plug just need lee one now Quote Link to comment Share on other sites More sharing options...
PaulMc Posted November 19, 2020 Share Posted November 19, 2020 The connector pictured in your first post, is a Bosch Jetronic connector, similar to the connectors in their commercial Jetronic range, but made for Volvo in a custom colour (grey). The connector, terminals and seals are available from Volvo, under the following part numbers - Housing = 979041 Terminals = 978261 (0.5 - 1.0mm²) Seals = 970772 The terminals and seals are standard TE (AMP) Junior Power Timer 2.8mm, which are available from many sources, including me . 3 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted November 20, 2020 Author Share Posted November 20, 2020 2 hours ago, PaulMc said: The connector pictured in your first post, is a Bosch Jetronic connector, similar to the connectors in their commercial Jetronic range, but made for Volvo in a custom colour (grey). The connector, terminals and seals are available from Volvo, under the following part numbers - Housing = 979041 Terminals = 978261 (0.5 - 1.0mm²) Seals = 970772 The terminals and seals are standard TE (AMP) Junior Power Timer 2.8mm, which are available from many sources, including me . They same as what’s on the v8 injectors? Quote Link to comment Share on other sites More sharing options...
PaulMc Posted November 20, 2020 Share Posted November 20, 2020 2 hours ago, Green200tdi said: They same as what’s on the v8 injectors? The 'Thor' V8 (D2 and late RR P38) uses similar Bosch Jetronic connectors (with detail differences and different keyways) The V8 injector connectors are YPC114900 (BMW 12521427615), and look like this - The Volvo connector looks like this - Aside from the differences in the body styles (position of boot retainer, bottom of connector and the height of the release clip), they are essentially the same connector. The only thing stopping you using V8 connectors on your fog lamps, is the keying along the top of the connector. The injector connector is Code I The Volvo connector is Code II If you trimmed-off the keyway lugs on your fog lamp's male connector, the injector connector should connect to it. . Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted November 20, 2020 Author Share Posted November 20, 2020 9 hours ago, PaulMc said: The 'Thor' V8 (D2 and late RR P38) uses similar Bosch Jetronic connectors (with detail differences and different keyways) The V8 injector connectors are YPC114900 (BMW 12521427615), and look like this - The Volvo connector looks like this - Aside from the differences in the body styles (position of boot retainer, bottom of connector and the height of the release clip), they are essentially the same connector. The only thing stopping you using V8 connectors on your fog lamps, is the keying along the top of the connector. The injector connector is Code I The Volvo connector is Code II If you trimmed-off the keyway lugs on your fog lamp's male connector, the injector connector should connect to it. . Yes that’s the one the GREY one two cut outs in it how much are they? Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted November 20, 2020 Author Share Posted November 20, 2020 Quote Link to comment Share on other sites More sharing options...
PaulMc Posted November 20, 2020 Share Posted November 20, 2020 1 hour ago, Green200tdi said: Yes that’s the one the GREY one two cut outs in it how much are they? I don't sell the connector housing, but looking on the web, I found this German site that's listing them for just over 4 Euros - https://www.skandix.de/en/spare-parts/accessories/din-assembly-parts/plugs/plug-housing-blade-terminal-sleeve-for-fog-light/1052953/ So, I would expect a similar (equivalent) price from a UK Volvo dealer or specialist. I can supply terminals and wire seals, if you need them. . Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted November 22, 2020 Author Share Posted November 22, 2020 Well all is well now, cut of original plug managed to remove old pin clean it up all working from a battery in the garage but now found out no power at pink or black wires so guess broken wire somewhere as n/s front fog light is working 🤔 may just run a wire from the other light. Quote Link to comment Share on other sites More sharing options...
