reb78 Posted December 5, 2020 Share Posted December 5, 2020 I think my thermostat on the 200tdi is not opening properly. I have a VDO gauge fitted that measures accurately. Normal driving, the engine is sitting at about 92C (So a few C higher than normal). On hills it was seeing 95C. I also realised today that I wasnt seeing that classic dip in temp as the thermostat opened initially. Top hose was cool when the gauge read 90C - it should be hot at this point I would say. On one test I shot up a steep hill rather quickly and the temps shot up to just under 100C briefly. Is this likely to have done any damage? This is a genuine stat ~2 years old. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 6, 2020 Share Posted December 6, 2020 Mines runs at 92°C, genuine thermostat and VDO gauge. Can get up to 94°C if I push it but I suspect my pushing it is not the same as yours 😉 Mo Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 6, 2020 Share Posted December 6, 2020 I replace my stat about every 2 years with genuine. I run a VDO sender to a MADMAN EMS. I have a VNT turbo fitted which runs the oil a bit hotter generally speaking. Standard 50mph cruising around in pretty much all weather it will be around 89-90°C, motorway cruising about 65mph average 91°C, pulling up some long hills and in the hot weather OAT of 25°C+ she'll nudge 92-93°C while I'm working it. 100°C for a short while shouldn't hurt it, but I'd double check all your hoses to make sure nothing is leaking just in case. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted December 6, 2020 Share Posted December 6, 2020 Because the cooling system is under pressure it can be hotter than 100°C without boiling. Attention, Physics 😁 Therefore, it can boil over immediately if you open the expansion tank and release the pressure. Temperatures up to slightly above 100°C are therefore ok 1 Quote Link to comment Share on other sites More sharing options...
reb78 Posted December 22, 2020 Author Share Posted December 22, 2020 Problem solved - new thermostat and its bang on 88/89C. The old one cant have been opening I think - this one I can see the temperature dip again when it opens up. 2 Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 22, 2020 Share Posted December 22, 2020 I treat thermostats as consumables for this reason, glad you sorted it. Quote Link to comment Share on other sites More sharing options...
