James Riddell Posted December 19, 2020 Share Posted December 19, 2020 Quote Link to comment Share on other sites More sharing options...
James Riddell Posted December 19, 2020 Author Share Posted December 19, 2020 New member. Hi my p38 will not go down to bottom light on my eas rocker switch I thought maybe the switch any ideas the front suspension sits Down overnight Quote Link to comment Share on other sites More sharing options...
elbekko Posted December 19, 2020 Share Posted December 19, 2020 When are you trying this? It'll only do it when you're actually allowed to go to access height (engine running, in park, foot off brake). Going down overnight is probably due to a leak somewhere. Take out the big black relay under the LH seat when parking up overnight to stop the system from self-levelling, then you can see which corner drops down. Quote Link to comment Share on other sites More sharing options...
Blanco Posted December 19, 2020 Share Posted December 19, 2020 .... opening a door stops mine going down as well. Quote Link to comment Share on other sites More sharing options...
Escape Posted December 20, 2020 Share Posted December 20, 2020 11 hours ago, Blanco said: .... opening a door stops mine going down as well. It should, but that's a bit hard if you can't park inside over night. 😉 I replace the timer relay with a standard 4-pin relay on all P38s. That way the EAS is only active when the ignition is on, so wont wake up to level when parked. Helps prevent loss of air and makes it easier to check for leaks as you'll know which corner drops (as @elbekko said). Do keep the timer relay in the car, as you'll need it to connect diagnostics. Unless you manage to cycle the ignition in exactly the right way to put the EAS into diagnostic mode. Filip Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted January 4, 2021 Share Posted January 4, 2021 On 12/20/2020 at 9:52 AM, Escape said: It should, but that's a bit hard if you can't park inside over night. 😉 I replace the timer relay with a standard 4-pin relay on all P38s. That way the EAS is only active when the ignition is on, so wont wake up to level when parked. Helps prevent loss of air and makes it easier to check for leaks as you'll know which corner drops (as @elbekko said). Do keep the timer relay in the car, as you'll need it to connect diagnostics. Unless you manage to cycle the ignition in exactly the right way to put the EAS into diagnostic mode. Filip Hi Filip , could you tell me where the timer relay is located on my car ? M/Y 2000 DSE , many thanks in advance regards Paul . Quote Link to comment Share on other sites More sharing options...
elbekko Posted January 4, 2021 Share Posted January 4, 2021 7 minutes ago, P38 Paul said: Hi Filip , could you tell me where the timer relay is located on my car ? M/Y 2000 DSE , many thanks in advance regards Paul . Should be under the LH seat, the big black relay. Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted January 4, 2021 Share Posted January 4, 2021 2 minutes ago, elbekko said: Should be under the LH seat, the big black relay. Cheers for that Filip , so I have just got to swap it out for a standard black or yellow relay that's used in the main fuse box ? Quote Link to comment Share on other sites More sharing options...
elbekko Posted January 4, 2021 Share Posted January 4, 2021 46 minutes ago, P38 Paul said: Cheers for that Filip , so I have just got to swap it out for a standard black or yellow relay that's used in the main fuse box ? I'm not Filip, that's @Escape But yes, just swap it out for a regular yellow one like is used in the fuse box (for example for the heater windscreen). Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted January 4, 2021 Share Posted January 4, 2021 5 minutes ago, elbekko said: I'm not Filip, that's @Escape But yes, just swap it out for a regular yellow one like is used in the fuse box (for example for the heater windscreen). Please forgive me elbekko , I do apologies as I am always getting you two mixed up , thanks for your help , regards Paul . 1 Quote Link to comment Share on other sites More sharing options...
elbekko Posted January 4, 2021 Share Posted January 4, 2021 3 hours ago, P38 Paul said: Please forgive me elbekko , I do apologies as I am always getting you two mixed up , thanks for your help , regards Paul . Oh, that's alright, a few people think we're brothers although we're not. And we usually hang out in the same places/threads... 1 Quote Link to comment Share on other sites More sharing options...
