larna86 Posted January 24, 2021 Share Posted January 24, 2021 All, Seeking advice from more experienced members - my synthetic winch line has a good chafe in it - see picture. Is this repairable or do I not need worry? It’s 10mm Dyneema and approx 10yrs old. Thoughts please! Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 24, 2021 Share Posted January 24, 2021 Split it and re-join it loads of you tube videos on how to do it looks very straight forward regards Stephen Quote Link to comment Share on other sites More sharing options...
western Posted January 24, 2021 Share Posted January 24, 2021 At 10 years old, if it was mine it would be replaced with a new rope, I don't even keep my steel winch cables that long. 2 Quote Link to comment Share on other sites More sharing options...
larna86 Posted January 24, 2021 Author Share Posted January 24, 2021 Thanks for the responses - will repair it and use as a spare extension, as I had bought a replacement just in case. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 24, 2021 Share Posted January 24, 2021 It is possible to cut and re splice it however it does create a thicker section in the rope. I've done this with one I snapped. But at ten years old I would seriously consider replacing it and cut it up for extensions etc. Mike 1 Quote Link to comment Share on other sites More sharing options...
SPendrey Posted January 26, 2021 Share Posted January 26, 2021 On 1/24/2021 at 4:08 PM, larna86 said: Thanks for the responses - will repair it and use as a spare extension, as I had bought a replacement just in case. That's exactly what I did. Bought a couple of metal loops for the ends to wrap around, cut out the bad bit (creating a new clean end), then used the splicing technique shown here... Quote Link to comment Share on other sites More sharing options...
