Souster Posted February 4, 2021 Share Posted February 4, 2021 Hi all Got to do the water pump on my TD5, Slight leak from the weep hole. Which brand would you go for, QH or pro flow? (Are genuine LR Quinton Hazell?) Anything else I should do while in there? Do all the seals that are required come with the pump? Any tips welcome. Cheers Quote Link to comment Share on other sites More sharing options...
paime Posted February 4, 2021 Share Posted February 4, 2021 1 hour ago, Souster said: Hi all Got to do the water pump on my TD5, Slight leak from the weep hole. Which brand would you go for, QH or pro flow? (Are genuine LR Quinton Hazell?) Anything else I should do while in there? Do all the seals that are required come with the pump? Any tips welcome. Cheers Can't advise on the brands but I did mine last year and I remember the drive belt tensioner being very, very stiffly sprung. If your power steering pump is old you might as well replace it at the same time, same goes for the belt. Otherwise it's just a few bolts and fairly straight forward. Quote Link to comment Share on other sites More sharing options...
reb78 Posted February 4, 2021 Share Posted February 4, 2021 As above^^^ also, if you are doing anything there (especially if you change the PAS pump) check the PAS pipe on that side of the block. If its the same setup as the disco it chafes against the top of the sump (i think). QH are OEM. Quote Link to comment Share on other sites More sharing options...
Souster Posted February 5, 2021 Author Share Posted February 5, 2021 Thanks alot guys. I will bare that in mind. I find the constant tension hose clips on the TD5 always seem to seep slightly. Is there any reason why they didn't fit worm drive hose clamps? I'm thinking of changing to those, any reason why I shouldn't? Quote Link to comment Share on other sites More sharing options...
paime Posted February 5, 2021 Share Posted February 5, 2021 i replace mine to jubilees whenever i get the chance! Those spring clips are horrible things, particularly if they're in an awkward place to get the grips on. No harm at all in changing them out. Quote Link to comment Share on other sites More sharing options...
reb78 Posted February 5, 2021 Share Posted February 5, 2021 Same^^^ Quote Link to comment Share on other sites More sharing options...
Landrovernuts Posted February 6, 2021 Share Posted February 6, 2021 I have done a few TD5 water pumps now including my own one and find it much easier to undo the whole auxiliary housing and remove from the engine. It is easy to get off but if you do take it off, remember to get a new seal. I have had one that no matter what way I tried to get the pump out it wouldn’t and two others have broken the bolt close to the engine which is a bit of a sod to get to anyway! Toby Quote Link to comment Share on other sites More sharing options...
reb78 Posted February 6, 2021 Share Posted February 6, 2021 I've tried both ways too and found it a pig of a job whichever! just thought. This might help the OP. Its a disco but essentially the same process as the engines were the same. http://www.discovery2.co.uk/waterpump.html Quote Link to comment Share on other sites More sharing options...
Souster Posted February 6, 2021 Author Share Posted February 6, 2021 Thanks everyone for your help posting. I'm going to give removing the housing a go, hopefully won't be too much of a pig. And replace the seal behind. Also going to fit a low coolant alarm in the header tank while the coolant is drained. Quote Link to comment Share on other sites More sharing options...
paime Posted February 7, 2021 Share Posted February 7, 2021 10 hours ago, Souster said: Thanks everyone for your help posting. I'm going to give removing the housing a go, hopefully won't be too much of a pig. And replace the seal behind. Also going to fit a low coolant alarm in the header tank while the coolant is drained. Can you post some pics of your coolant alarm when it's done? I saw the British Canadian chap install one on a square header tank but was wondering how it would work on the round TD5 tank. Quote Link to comment Share on other sites More sharing options...
reb78 Posted February 7, 2021 Share Posted February 7, 2021 Isnt there a bmw header tank that will fit with the low coolant sensor fitted? I am sure i have read that somewhere. Quote Link to comment Share on other sites More sharing options...
