Mean Green Posted March 4, 2021 Share Posted March 4, 2021 Should there be shims between the chassis and rear tub on a 200tdi 90? I have my refurbished tub back from the painter and a new galv chassis. But the tub is fouling on the top of the fuel tank and will not sit down onto the brackets on the chassis, should there be shims between the chassis and tub? I know there is a pad - presumably as an aid to stopping vibration, but should there also be shims to adjust the tub alignment on the chassis? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 5, 2021 Share Posted March 5, 2021 If you mean under the floor then just the rubber pads riveted to the under-floor supports. The tank is a squeeze fit between tub and cradle, so its normal to have to compress it a few mm. Quote Link to comment Share on other sites More sharing options...
Litch Posted March 5, 2021 Share Posted March 5, 2021 (edited) You say it is a 90 so are we talking standard 200TDi underseat fuel-tank or a TD5 style rear-mounted tank? Whichever it is then no, I have never come across any shim other than the isolating pads. Looking at the photo below (taken 12-months ago when I had just put the rear tub onto my new chassis) there is only one place where the rear tub gets anywhere near the top of the tank (the seatbox seam) but even so there is still a significant gap with no danger of the tub touching the tank. Edited March 5, 2021 by Litch Typo Quote Link to comment Share on other sites More sharing options...
Mean Green Posted March 5, 2021 Author Share Posted March 5, 2021 Exactly my set up Litch - even the same colour! My tub edge is sitting on the tank and there is a gap of a few mm between the chassis and tub floor. It is also new YRM tank brackets - will have a look and see if bracket can drop any. Quote Link to comment Share on other sites More sharing options...
Litch Posted March 5, 2021 Share Posted March 5, 2021 Which chassis, mine is a Richards? What tank brackets do you mean? I fitted a Richards galvanised front bracket (despite already having a galvanised on on my existing chassis) but at the rear it just bolts through to the outrigger and those holes aren't slotted. The holes in the tank may be slotted (can't remember) so you just need to make sure it is a low as possible. Other than that I can only presume that the outrigger may be bent (unlikely to have been welded in the wrong position as they are jigged)? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 5, 2021 Share Posted March 5, 2021 What are the holes like in the tub where it mounts at the front? Have they rotted and elongated? Although if its hitting the tank, but NOT touching the chassis under the floor (with the rubber isolators in), that would hint to me that the tank is too high? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 6, 2021 Share Posted March 6, 2021 Apologies - don’t know why my mind jumped to Td5 tank when you specifically said 200Tdi! Mine sat with plenty of clearance as above. I did have to widen the small hole for the breather hose though, as it wouldn’t sit properly when lined up. I presume the spigot was in the wrong place on the new tank. Quote Link to comment Share on other sites More sharing options...
Mean Green Posted March 7, 2021 Author Share Posted March 7, 2021 (edited) Slackened off the tank this morning, just in case there was enough 'slack'. Had a good look and it appear that I am missing one of the tub floor pads, but it still does not look like it will haev enough clearance - even with a spacer in place. Will order some up and see what happens. In my enthusiasm to pull it all apart I didnt take any photographs... wish I had now! Edited March 7, 2021 by Mean Green Quote Link to comment Share on other sites More sharing options...
Litch Posted March 7, 2021 Share Posted March 7, 2021 Ohhhhh... Never a good decision. Lots of photos. Labels on any wire / cable / pipe. Drawings / notes to act as an aid memoir. Lots of boxes / plastic tubs (clearly labelled) for assorted fixings / parts. Quote Link to comment Share on other sites More sharing options...
Mean Green Posted March 7, 2021 Author Share Posted March 7, 2021 I labelled all the cables and have all the parts labelled in boxes for each section... bulkhead, doors etc ... but I didnt take pictures of the strip down Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 7, 2021 Share Posted March 7, 2021 Took this photo of mine a while back if it helps? Just ignore the horror show of the rot Quote Link to comment Share on other sites More sharing options...
Litch Posted March 7, 2021 Share Posted March 7, 2021 Going off topic here but that is a perfect example of why I favour stripping the body when doing a chassis swop (see other thread on here). Lifting the body (inc seatbox & sills) as one unit, that sort of corrosion is unseen and by the time it eventually found it is possibly too late for an "easy" repair. As for the gap between the tub and the tank, that matches my photo shown earlier. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 7, 2021 Share Posted March 7, 2021 Have you got the bolts in the front mounts of the tub? on the tubular outriggers. Quote Link to comment Share on other sites More sharing options...
