Converting a Tdi to di in a series
steve b
The particular installation is already in use with the turbo fitted but no intercooler which brings it's own set of risks ...
As it is bolted to the front of a 2a gearbox my preferred solution would be to remove the turbo to reduce power and torque to a better level for this box.
What exhaust manifold is the best fit ?
Longer term it will go back to it's original spec 2 1/4 diesel 3mb engine - see my wanted ad
thanks
Steve
Not looking for Tdi power and torque as this should make clear ...
Just a short term reduction in power/torque and associated combustion heat until the right original spec diesel can be sourced .
Steve
Thanks for the link , I have already offered up the 2.5 3 stud exhaust manifold to a spare tdi engine and thought it could work with a bit of grinding and some bridge clamps , I'll read through it .
Steve
  • Like 1
When I converted my series to Di, I used a 300tdi manifold which I placed a blanking plate in place of the turbo and wired off the exhaust gate so it wouldn't move. This combination worked fine for me for several years.
