discomikey Posted July 15, 2023 Share Posted July 15, 2023 That looks like an awful lot of fun. Always happy to help next time and we have since brought more of our own manufacturing and stock in-house so hopefully timescales will be less of an issue. Thanks again for the enquiry. I still haven't seen Fast X but it's on the list! Quote Link to comment Share on other sites More sharing options...
simonr Posted July 15, 2023 Author Share Posted July 15, 2023 This is one of the jump cylinder tests. It's at quite low pressure here - we were trying to tune the pressure & exhaust valve timings to jump, then absorb as much of the impact as possible on landing. IIRC the concrete block was 700kg. https://youtu.be/IFFuSKjjOpg This shows how the suspension on the vehicle was going to work. There's no way the coil-over would extend fast enough when the jump cylinder fired - so we mointed it on a swing arm. It extends at it's own pace then just tidies up the last bit of energy on landing. https://youtube.com/shorts/ZKzf2hKQMhE This was the suspension setup on the test vehicle If you look below the jump cylinder rod, you can see a clevis with two holes. We kind of cheated, and put a steel wheel in here which hovered 50mm off the road such that on takeoff or landing, you see the tyre compress, but it didn't put too much force through the end of the axle. We also had to add bump-stops on top of the coil over swing arm as on landing, there was enough force to bust stuff. This just softened the impact a bit. In the end, this was all canned in preference for traditional slug-firing canons. Marcus, Mikey & Joe (built all the test rigs & conducted the testing itself) - if you ever see this, you did an amazing job! 2 Quote Link to comment Share on other sites More sharing options...
hurbie Posted July 15, 2023 Share Posted July 15, 2023 @simonr can't see the video's , there on private settting . Quote Link to comment Share on other sites More sharing options...
simonr Posted July 15, 2023 Author Share Posted July 15, 2023 6 minutes ago, hurbie said: @simonr can't see the video's , there on private settting . Doh! It should be fixed now. Quote Link to comment Share on other sites More sharing options...
