landy_andy Posted April 22 Share Posted April 22 An currently working on installing a GM hydro booster in my D100 to compliment the Chevy 3/4t callipers on my 609 axles, if any ones interested I'll post up progress... let me know. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted April 23 Share Posted April 23 12 hours ago, landy_andy said: An currently working on installing a GM hydro booster in my D100 to compliment the Chevy 3/4t callipers on my 609 axles, if any ones interested I'll post up progress... let me know. Absolutely interested regards Stephen Quote Link to comment Share on other sites More sharing options...
landy_andy Posted April 23 Author Share Posted April 23 Starting with a used booster off a 2006 Chevy Silverado 2500. Whilst removing the unit from the factory mounting plate the nut decided to break into 3 pieces, welded it back together whilst I looked for a replacement. As luck would have it a regular LR spindle nut is exactly the same thread. Quote Link to comment Share on other sites More sharing options...
landy_andy Posted April 23 Author Share Posted April 23 Next I cut the clevis off the original vacuum booster with a short piece of the shaft left up to the point it reduced in diameter. Plan is to cut the eye off the hydro booster shaft, thread both as there 3/8” diameter and use a simple threaded joiner & jam nut. This will make service/replacement in the truck an easy job if required. Here we are working out the length of adaptor required to make this all work. Seems 2” is the magic length between the front face of the brake pedal tower and the booster. 1 Quote Link to comment Share on other sites More sharing options...
landy_andy Posted April 23 Author Share Posted April 23 With a bit of CAD magic we have a custom adapter drawn up and the end plates are out for water jet cutting from 1/4” steel. Should see those in a week or two. Quote Link to comment Share on other sites More sharing options...
landy_andy Posted April 23 Author Share Posted April 23 Whilst I wait for the cut parts, did some searching and figured out all the part #’s for the adapter fittings to use 6AN hose & fittings as I already have that on my 5.3 LS PAS pump setup. There all on order and will add those to the next update. Next to give the pedal tower & booster a good clean & fresh coat of paint ready for reinstalling. 2 Quote Link to comment Share on other sites More sharing options...
landy_andy Posted May 1 Author Share Posted May 1 Got some parts in, clean & repainted the booster… AN6 adapters added & just waiting for the water jet cut parts to get it installed. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted May 1 Share Posted May 1 Excuse the dumb question, why and how much better is this over the standard vacuum servo. Mike Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 1 Share Posted May 1 38 minutes ago, miketomcat said: Excuse the dumb question, No dumb questions if there is knowledge to be gained Regards Stephen Quote Link to comment Share on other sites More sharing options...
landy_andy Posted May 1 Author Share Posted May 1 8 hours ago, miketomcat said: Excuse the dumb question, why and how much better is this over the standard vacuum servo. Mike No dumb questions here… basically the hydro boosters give you approximately double the hydraulic pressure to your calipers over vacuum boosters for the same amount of pedal pressure. It’s an easy way to get a significant improvement in braking performance when going to larger tires and when you mix & matching brake parts. With the physical limitations on caliper size by keeping my 15” Stazworks rims I opted to use single piston Chevy 3/4t calipers all round on the 609 axles. There cheap & readily available but obviously won’t perform as well as a more modern 4 pot caliper. So, to offset this hydro boost gives me a ‘boost’ in line pressure. Will see how it performs once it’s all back together. If I’m not happy then there is the option to swap the calipers out for ones from Wilwood. They make 4 pots in the same physical size but there $300 each ☹️ Here is a great tech article on brakes for off-road trucks : Billavista’s Brake Bible….. To note, most 3/4t and all 1t pickups here have hydro boost brakes from factory due to their increased weight and the heavy loads they can tow. Hope that answers your question 👍 Quote Link to comment Share on other sites More sharing options...
landy_andy Posted May 1 Author Share Posted May 1 Here are a few pictures of the clearance I have on the (rear) rims and the custom front caliper brackets I designed based off this data to work with the modified Dodge 1t knuckles. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted May 1 Share Posted May 1 Thank you. So I guess it kind of works in a similar way to a steering box. Mike 1 Quote Link to comment Share on other sites More sharing options...
landy_andy Posted May 1 Author Share Posted May 1 28 minutes ago, miketomcat said: Thank you. So I guess it kind of works in a similar way to a steering box. Mike Yup…. if you look in the tech article I posted, near the bottom is an explanation on how they work. Quote Link to comment Share on other sites More sharing options...
landy_andy Posted May 7 Author Share Posted May 7 Picked up the cut parts & some more TIG practice, really happy how this is coming along. Next to pick up an ACDELCO 18M230 master cylinder as it has a 1 5/16” bore that’ll move lots of fluid for my Chevy 3/4t calipers. 1 Quote Link to comment Share on other sites More sharing options...
simonr Posted May 8 Share Posted May 8 On 5/1/2022 at 5:11 PM, landy_andy said: I detect Solidworks 🙂 I'm guessing you use it professionally - unusual to see a fully defined sketch! If you do a lot of Sheet Metal or Weldments, find me on You're making a beautiful job of it (the build). I've seen Hydro Boost brakes - but never seen someone adapt one to a Land Rover. Si Quote Link to comment Share on other sites More sharing options...
landy_andy Posted May 8 Author Share Posted May 8 4 hours ago, simonr said: I detect Solidworks 🙂 I'm guessing you use it professionally - unusual to see a fully defined sketch! If you do a lot of Sheet Metal or Weldments, find me on You're making a beautiful job of it (the build). I've seen Hydro Boost brakes - but never seen someone adapt one to a Land Rover. Si Nope… just a hobbyist, you missed the link Si. There are a few kits around for LR’s but I wasn’t going to pay what they wanted for them. I only paid $110cdn (70 quid) for the take-off booster shipped and the cut parts were another $40 as I had 2 sets made. Biggest investment are the Earls fittings etc. Going to be interesting to see how it all performs once complete. Thanks for the compliment, it’s been a very long haul… only seems like yesterday when I did the last LRO show with Dave Marsh before we emigrated… that was in ‘07 ☹️ 1 Quote Link to comment Share on other sites More sharing options...
simonr Posted May 8 Share Posted May 8 12 minutes ago, landy_andy said: Nope… just a hobbyist, you missed the link Si. There are a few kits around for LR’s but I wasn’t going to pay what they wanted for them. I only paid $110cdn (70 quid) for the take-off booster shipped and the cut parts were another $40 as I had 2 sets made. Biggest investment are the Earls fittings etc. Going to be interesting to see how it all performs once complete. Thanks for the compliment, it’s been a very long haul… only seems like yesterday when I did the last LRO show with Dave Marsh before we emigrated… that was in ‘07 ☹️ I was going to say - but the second bit vanished! If you do a lot of Sheet Metal or Weldments, find me on - the solidworks forum, I've posted some useful macros on there. Particularly one which will traverse all the parts in an assembly, find the sheet metal bits, export the flat patterns as DXF's (for laser / Plasma / jet cutting) along with a Bill of materials for how many & of what material & thickness. I use that every couple of days! Are you the same Landy_Andy I used to know? Big Pete's sidekick?😉 Quote Link to comment Share on other sites More sharing options...
landy_andy Posted May 8 Author Share Posted May 8 We met quite a few times at shows, I made the 3Link that ‘Gon-2-Far’ then ‘QT’ we’re selling… don’t really do that now. Just keep myself amused in the shop after dealing with avalanches in winter & MVI’s on the highway year round. Quote Link to comment Share on other sites More sharing options...
landy_andy Posted June 9 Author Share Posted June 9 After a few fails…. found a master cylinder that’d fit under the hood, have an acceptable bore and not be made out of cast iron. Next to work on the new brake & hydraulic lines. 1 Quote Link to comment Share on other sites More sharing options...
simonr Posted June 9 Share Posted June 9 On 5/8/2022 at 11:46 PM, landy_andy said: We met quite a few times at shows, I made the 3Link that ‘Gon-2-Far’ then ‘QT’ we’re selling… don’t really do that now. Just keep myself amused in the shop after dealing with avalanches in winter & MVI’s on the highway year round. I remember you! You also (I think) made me some beautiful foil 'blister' X-Eng Stickers! I've used something very similar to your 3 Link topology too. I hope you're doing well. I'm a little envious of you moving to Canada! 1 Quote Link to comment Share on other sites More sharing options...
landy_andy Posted June 15 Author Share Posted June 15 My 3/8-24 die, coupler & jam nuts arrived today. Cut the threads & assembled things up, had to trim the stub shaft on the booster down to 1.5” overall to get a bit of free play on the pedal. 2 1 Quote Link to comment Share on other sites More sharing options...
landy_andy Posted June 22 Author Share Posted June 22 Pedal box reinstalled & time to get things connected up with some Earls hose. Just need a 45 degree fitting to finish it off now. 3 Quote Link to comment Share on other sites More sharing options...
