tommobot Posted July 13, 2022 Share Posted July 13, 2022 I'm looking to order some new discs and pads for my very early 'one ten'.. Offically its a 'one ten' but at somestage in its life it was fairly modified transmittion wise to have 200tdi drivetrain. I've read that all front discs and pads are the same, but I specifically saw a listing for 'one ten' front discs which makes me think that there not. Also, I'm fairly confident that the front hub arrangment changed at somepoint in the 200tdi era...? Whats the best way to confirm either way which ones I need to order? - I guess strip down and measure? Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted July 13, 2022 Share Posted July 13, 2022 Hey cool! Mine is MY83 and was first registered in '86 with V8. It has a 200Tdi since the early 90s as well. Discs are the solid ones which are not so thick as the vented ones. As far as I know, vented discs came with the 300Tdi. Calipers are the same size, but with a spacer between the halfes, to make them suitable to the vented discs. Quote Link to comment Share on other sites More sharing options...
tommobot Posted July 13, 2022 Author Share Posted July 13, 2022 Slightly confused by this listing, as its the only one i've seen thats saying for 'one ten' upto 1986. Anyone know what the difference is, if any as at face value they look the same https://www.bearmach.com/product/brake-pad-disc-kits-brkbkbpk/geomet-front-brake-disc-pad-kit-suitable-for-defender-one-ten-vehicles-up-to-1986-bk-1000geo/BK 1000GEO?glCountry=UK&glCurrency=GBP&gclid=CjwKCAjw2rmWBhB4EiwAiJ0mtcYGdMZh1Op44w_cOexig4k85_hrebn0RAbB26B_uIYZ4TJuzewMlhoCHcYQAvD_BwE Quote Link to comment Share on other sites More sharing options...
western Posted July 13, 2022 Share Posted July 13, 2022 https://britcar.com/product.php/160160/3647/brake_disc___front___solid___defender___discovery_1___range_rover_classic are 110 front solid non vented discs. Pads either have 2 retaining pin holes or the plate clips as in the Bearmach link. Quote Link to comment Share on other sites More sharing options...
tommobot Posted July 13, 2022 Author Share Posted July 13, 2022 (edited) So the disks are consistant? its just the pad retainers that are different..? I'll have a sneaky look and see what I have on the calipers.. Edit, looks like its 2 retaining pin holes so I presume I can get anything from 86- circa whatever... Edited July 13, 2022 by tommobot Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted July 13, 2022 Share Posted July 13, 2022 (edited) maybe this helps too and this: Edited July 13, 2022 by Sigi_H 1 Quote Link to comment Share on other sites More sharing options...
tommobot Posted July 13, 2022 Author Share Posted July 13, 2022 Lovely, very helpful video! - Thanks for the link!👍 Quote Link to comment Share on other sites More sharing options...
tommobot Posted November 2, 2022 Author Share Posted November 2, 2022 These have been rattling away for long enough, time to sort it! I think the metal retaining clips will fit - such as: https://www.gsfcarparts.com/catalog/product/view/id/175706/?auto_apply_coupon=AUT65&gclid=Cj0KCQjwqoibBhDUARIsAH2OpWhkBIHdDdpwa9fgkFM9euN9MCTj1TGjaXWrpANCOOHPL31TosRCJrsaAowCEALw_wcB Would someone just confirm this for me please.. Quote Link to comment Share on other sites More sharing options...
Snagger Posted November 2, 2022 Share Posted November 2, 2022 If memory serves correctly, the differing pins and springs are not compatible with the opposite pads - the earlier pads have the flanges for the pins to pass through and coil springs to press on, while I think the later pads are shaped closer to the friction lining for the plate spring to sit under the split pin. The spring has to be full width to press the steel backplates, and the early flanges would prevent the plate spring being fitted. The online order site would be specific about 110 pads as the 90, RRC and Discovery all had smaller front brakes than the 110. I believe the One-Ten and 200Tdi Defender 110 have identical axles, including brakes (there maybe width differences in the brackets for the radius arms, but I suspect that also changed with the 300Tdi, like all the other changes). Quote Link to comment Share on other sites More sharing options...
western Posted November 2, 2022 Share Posted November 2, 2022 38 minutes ago, tommobot said: These have been rattling away for long enough, time to sort it! I think the metal retaining clips will fit - such as: https://www.gsfcarparts.com/catalog/product/view/id/175706/?auto_apply_coupon=AUT65&gclid=Cj0KCQjwqoibBhDUARIsAH2OpWhkBIHdDdpwa9fgkFM9euN9MCTj1TGjaXWrpANCOOHPL31TosRCJrsaAowCEALw_wcB Would someone just confirm this for me please.. the plate springs are for the other pad type as shown in the video above, as your pads have the 2 holes & coil spring & pins keep the same retainers again as in the video. Quote Link to comment Share on other sites More sharing options...
tommobot Posted November 2, 2022 Author Share Posted November 2, 2022 Hmmmm so by the sounds of it, they are 'correct' as they are then... So to stop the rattling is there any approved method? - Could I put a small rubber sleeve over the retaining pin to try and compress the spring slightly? - They don't really seem to have any compression to them at all at the moment.. Quote Link to comment Share on other sites More sharing options...
western Posted November 2, 2022 Share Posted November 2, 2022 Just stretch the spring a bit, I have the same retaining pins on my 89 110CSW & haven't noticed any pad rattle in 25 years. Quote Link to comment Share on other sites More sharing options...
Junglie Posted November 2, 2022 Share Posted November 2, 2022 The rattle must be spectacular for it to be audible in a moving Landy, surely? My '85 110 does a masterful job of drowning out any superficial rattles with engine and transmission noise, plus road noise, tyre roar and so on. I'm really looking forward to getting it that quiet... 1 Quote Link to comment Share on other sites More sharing options...
tommobot Posted November 3, 2022 Author Share Posted November 3, 2022 10 hours ago, Junglie said: The rattle must be spectacular for it to be audible in a moving Landy, surely? My '85 110 does a masterful job of drowning out any superficial rattles with engine and transmission noise, plus road noise, tyre roar and so on. I'm really looking forward to getting it that quiet... Its running a BMW M52 petrol and fairly 'roady' tyres so pottering about at 30mph its near silent (for a 84' 110 😀) 1 Quote Link to comment Share on other sites More sharing options...
