Rear wiring loom colour check 1993 90
I am trying to understand my wiring loom and wondered if you folks can check what I have and perhaps fill in the ones I am missing.
I have unwrapped my wiring loom where it enters at the front (just in front of the bulkhead outrigger) to travel toward the rear. The colours I have are as follows:
Purple  -
Red/yellow - fog lights
Red/Orange  - RH Tail light
Red/Black - LH Tail light
Green Purple- Brake lights
Green/Red - Left indicator
Green/Black - RH indicator
Green/White -
Green/Brown - reverse
White/Purple  - Fuel pump
So what is Purple and what is Green/white?
Thanks for your help
Mick
24 minutes ago, western said:
Purple is always live 12v from battery
Green/White is RH indicator
Green/Black is fuel sender to gauge NOT indicator
Thanks Western, I really appreciate that.
Well the Purple certainly wasn't live when it got to the rear!
Also the loom has obviously had a join in the past.
7 hours ago, western said:
It's had better times.
I can only agree with you there.
I have decided to bite the bullet and fit a length of trailer cable to the back. It would not be my preferred option but the loom is quite stiff, which I presume is age related, and the tape wrapping it is not as adhered as it once was. I have decided to route the loom along the top of the chassis so I feel a multi core cable with its own outer sheath would offer better protection. My thoughts are to have this in split convoluted tube P clipped to the chassis.
I don't like diverging from the standard LR wiring colours, but at least with using standard trailer wiring the colours will be a  standard in the main.
I had to remove the chassis loom during the change, on refit I decided to route it along the outside upper face in split convoluted tube, cable tied to other pipes along the top & some chassis brackets, it's been fine in the lsdt 8 years, I do have a new Autosparks chassis loom to replace the old one, when I get around to it.
  • Like 1
Like Western-guru I have also got my loom outside in convoluted tube. What I like best is the confidence there won't be weird shorts/blown fuses where the barely protected loom rubs through on sharp bits somewhere inside the chassis...
  • Like 1
Having it on the top will mean I know where it is so when cleaning and treating inside, or indeed any welding required. I will have to make sure I treat underneath the conduit first as I can see that collecting crud.
