Mating a P38 gearbox (that came with the M51) to a Rover v8 4.0
The early P38 doesn't use CANbus, but you'll still need the ECU and all the inputs it expects (including from the diesel engine) to get the box to work properly.
At the engine side, there is a different torque converter, though you might be able to reuse the one from the V8 along with the bellhousing. At the rear, the transfer box of the P38 sits on the other side, not sure the bolting pattern and output shaft are compatible with the older transfer box.
Certainly not a straight fit.
  • Like 1
  • 2 weeks later...
On 10/16/2022 at 12:58 PM, Tollman said:
You need an extra hydraulic controlled 4hp22 and mix parts with the 4hp24e:
Use bellhousing and gears from 4hp24e and gearbox housing and output shaft (and also output housing) from 4hp22.
In this way you end up with hydraulic controlled 4hp24.
Edit: uhm.... I was dreaming that you wanted to fit the ZF together with the M51! :D:D
Edited by Carloz
  • 2 weeks later...
