trickydicky Posted March 10, 2023 Share Posted March 10, 2023 hi i have a recently tried to fit LED headlights and noticed the blue and red wire to the headlights is permanently live my old headlights worked ok but they were very dim iv changed the light switch and that's not helped could this be a relay problem ? how would i test for this ?if i pull the left light fuse it goes out .the blue and red cable going to the main beam switch is live .would a dodgy relay be able to make the cable live when the key isn't inserted? Quote Link to comment Share on other sites More sharing options...
western Posted March 10, 2023 Share Posted March 10, 2023 What year & vehicle, it maybe a faulty dim dip unit. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted March 11, 2023 Author Share Posted March 11, 2023 its a 1991 defender 90 200tdi iv changed the dim dip switch if thats what you mean ? Quote Link to comment Share on other sites More sharing options...
Peaklander Posted March 11, 2023 Share Posted March 11, 2023 This diagram might help. It's a simplified circuit to help me with any dipped beam fault finding. I have removed the dim / dip relay and you can see in my diagram that it is replaced with a piece of wire across the relay base that provided a short between the blue/red cables. 1996 300TDi Quote Link to comment Share on other sites More sharing options...
trickydicky Posted March 11, 2023 Author Share Posted March 11, 2023 i have taken the dash apart this morning and gone over pictures of the bulkhead with the loom showing when i fitted the chassis and i carnt find the red relay .my 200 was one of the first .maby it didnt have one ? Quote Link to comment Share on other sites More sharing options...
trickydicky Posted March 11, 2023 Author Share Posted March 11, 2023 iv now pulled every fuse and relay in the car (that i can find ) and its still got power . i have absolutely no idea what it could be .i unplugged the dim dip unit and the power went off so iv ordered a used one hopefully that one works fingers crossed Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted March 11, 2023 Share Posted March 11, 2023 Dim Dip isn't a legal requirement. Unplug the unit and forget about it. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted March 11, 2023 Author Share Posted March 11, 2023 iv literally just tried that and everything works except when the key is removed but that's a good thing if you ask me .anyway thanks again for all your help . hopefully see you out on the lanes Quote Link to comment Share on other sites More sharing options...
