Maverik Posted May 28, 2023 Share Posted May 28, 2023 Can anyone help me identify the correct crimping tool for the "open barrell splice" type crimps as pictured below. Wire sizes 18.5 - 13.5 AWG and 12 - 9 AWG really struggling, I've been using a terminal crimping tool, but its not wide enough to get the whole crimp in so you do half of it at a time, it's a real pain. Thought it would he a good "quick" way for joining wires, turns out it takes me twice as long as what I was doing before. Quote Link to comment Share on other sites More sharing options...
ped Posted May 28, 2023 Share Posted May 28, 2023 something like these i think but i'v never used them type pf jointers-i have used model making brass tube before and used .22rf cases i know we have a set of them along with a much bigger set for full size battery cables Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 28, 2023 Share Posted May 28, 2023 @PaulMc or @FridgeFreezer will know Quote Link to comment Share on other sites More sharing options...
PaulMc Posted May 28, 2023 Share Posted May 28, 2023 For open-barrel splice crimps, in the sizes you quote, I use the conductor die on this type of terminal crimper - On most tools of this type, the conductor crimp die is 6mm long. For larger splice crimps, I use tools designed for open-barrel copper lugs - 1 Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 29, 2023 Author Share Posted May 29, 2023 18 hours ago, PaulMc said: For open-barrel splice crimps, in the sizes you quote, I use the conductor die on this type of terminal crimper - On most tools of this type, the conductor crimp die is 6mm long. For larger splice crimps, I use tools designed for open-barrel copper lugs - Thanks @PaulMc great info as usual 👍 Where about do you get your tools from? Quote Link to comment Share on other sites More sharing options...
PaulMc Posted May 29, 2023 Share Posted May 29, 2023 7 hours ago, Maverik said: Thanks @PaulMc great info as usual 👍 Where about do you get your tools from? I've got them from various manufacturers - TE (AMP), Rennsteig, Pressmaster, Hozan, Hero, Engineer, Iwiss, Durite, etc... I've also bought quite a few from AliExpress (which is where the yellow handled ones for open-barrel copper lugs came from) The first one I pictured is a Durite 0-703-50 - available from numerous sellers. Here are some links to AliExpress for the copper lug crimpers - https://www.aliexpress.com/item/4001251385556.html https://www.aliexpress.com/item/1005001907184837.html https://www.aliexpress.com/item/4000283523527.html https://www.aliexpress.com/item/32846061927.html There are lots of other suppliers on AliExpress for these. . Quote Link to comment Share on other sites More sharing options...
Maverik Posted June 12, 2023 Author Share Posted June 12, 2023 To close this a little, I found these for a bargain price on ebay. Wire Crimper Crimping Pliers Jaw JX-1601-2546 AWG14-10 2.5-6mm² Bootlace R9I2 | eBay They fitted perfectly in a ratchet crimper I had already. Quote Link to comment Share on other sites More sharing options...
