Green200tdi Posted June 25 Share Posted June 25 Would a 300 tdi air box work on a 200 tdi engine? the 110 is in the n/s inner wing so thinking might be better on the engine.🤔 1986 c reg 110. Quote Link to comment Share on other sites More sharing options...
Ibex94 Posted June 25 Share Posted June 25 (edited) So as a C plate your truck probably started life as a 19J turbo diesel in which case the air filter set up was very similar the defender 200tdi as they both had high mounted turbos. Why do you want to change the air filter, what do you perceive to be the benefit? Â Which 200tdi do you have fitted, defender or disco? stick up some picks if you can. My Ibex has the air filter on the off side as I couldn't get to the side of the vehicle for a snorkel on the n/side. Â Edited June 25 by Ibex94 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted June 25 Author Share Posted June 25 3 hours ago, Ibex94 said: So as a C plate your truck probably started life as a 19J turbo diesel in which case the air filter set up was very similar the defender 200tdi as they both had high mounted turbos. Why do you want to change the air filter, what do you perceive to be the benefit?  Which 200tdi do you have fitted, defender or disco? stick up some picks if you can. My Ibex has the air filter on the off side as I couldn't get to the side of the vehicle for a snorkel on the n/side.  Can’t say what the original engine was but when my dad first got it in 2005 it was a 6 cylinder Nissan non turbo then he had the 200 tdi disco engine fitted, the air filter housing was in the n/s inner wing held in by cable ties (yes bodged by whom ever fitted the 200) last time I changed an air filter on it was a pain to get out if it’s on top of engine like the 300 lot easier to replace. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted June 26 Share Posted June 26 Disco 200tdi in a 110 and 90 both use disco 200 airbox. Mike Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 26 Share Posted June 26 If it fits & you can get the pipe on it, it works. I run 200TDi filters on my V8's. Quote Link to comment Share on other sites More sharing options...
Ibex94 Posted June 26 Share Posted June 26 Can’t remember the manufacturer of my filter but it’s the same as they use on the Wolf and I could get all the hoses to point in the right direction and get it under the bonnet. as Fridgefreezer say if it fits….. Quote Link to comment Share on other sites More sharing options...
