Hawklord Posted August 18, 2023 Share Posted August 18, 2023 While checking under my 300TDI I noticed some rust around one of the two 'bowls' which are on the underside of the battery tray and after pushing, it broke off completely. Any suggestions on what to do as I don't really want to replace the whole tray if at all possible as the surrounding metal is sound. There is a grid visible in the hole which the battery fixing rod attaches to. Quote Link to comment Share on other sites More sharing options...
fmmv Posted August 18, 2023 Share Posted August 18, 2023 Those pieces are there to discourage water from coming in. So maybe make new 'bowls' and weld on? I don't think they are vital provided the battery is clamped down. Quote Link to comment Share on other sites More sharing options...
western Posted August 18, 2023 Share Posted August 18, 2023 If the battery is secure, you can do away with those bowls, I took them off my 110 ages ago. Quote Link to comment Share on other sites More sharing options...
Ibex94 Posted August 18, 2023 Share Posted August 18, 2023 1 hour ago, western said: If the battery is secure, you can do away with those bowls, I took them off my 110 ages ago. Took them off or just witnessed the self disassembly?😩 Quote Link to comment Share on other sites More sharing options...
western Posted August 18, 2023 Share Posted August 18, 2023 I removed them as the batteries I have fitted needed more space thst the original clamp J bolts took up. Quote Link to comment Share on other sites More sharing options...
Hawklord Posted August 19, 2023 Author Share Posted August 19, 2023 Thanks for your replies and have decided to fabricate a patch to cover the hole. Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted August 21, 2023 Share Posted August 21, 2023 Don't forget that in a roll over situation if your batteries are not clamped down the batteries potentially connect with the metal under side of the seat box (battery positive to grounded body work !!!!). You probably don't want to add to your roll over problems by incinerating your Landrover. Or perhaps you do ..... I've just fitted a strip of rubber insulation to the underside of the seat box. Mike Quote Link to comment Share on other sites More sharing options...
western Posted August 24, 2023 Share Posted August 24, 2023 The J bolts are not removed, it's just the little boxed areas on bottom outside face that are removed Quote Link to comment Share on other sites More sharing options...
