Lockylockwood Posted September 6, 2023 Share Posted September 6, 2023 I am looking to purchase some forward facing rear seats for my defender 90 2.5 TD. It’s an old model so I’m not sure if the puma forward facing rear folding ones will fit. any advice welcome Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 6, 2023 Share Posted September 6, 2023 They don’t fit unless you modify the wheel boxes. If you look in the back of the puma, the wheel boxes are a different shape. I did see you could buy the panel and retrofit them … but it is perhaps easier to just get the right seats. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 6, 2023 Share Posted September 6, 2023 Here are the panels - which show the different shape: https://wildbear4x4.com/products/defender-seat-box-puma-conversion Though their text makes it sound like you have to fit those to have forward facing rear seats - you don’t. I have one from exmoor trim that’s good. 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 6, 2023 Share Posted September 6, 2023 4 minutes ago, Anderzander said: I have one from exmoor trim that’s good. Ahh they have a new design … and my god the price has gone up. https://www.exmoortrim.co.uk/seating/defender-load-area/loc-and-fold-right-hand.html Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 6, 2023 Share Posted September 6, 2023 I used a pair of Defender front seats for the second row, with 2mm steel sheet “tins” acting as the inboard legs and the outboard rail bolted to the existing but reinforced wheel boxes. Work well and have the same head room and leg space as using the folding late Defender rear seats. If you use captive fixings, or better still, a quick release system, then you would retain the load bay flexibility. http://www.nickslandrover.co.uk/only-a-few-jobs-left-to-do/ I had the old Exmoor folding rear seats, but they are narrow and, when mounted as intended, are difficult to access or even lock the legs or backs in position. Their seat belt geometry was dire, too. Because of all that, I moved them outboard with the hinges set on 1/2” plinths to allow the base frame to clear the wheel box. Sorted all of the issues except for head room for adults, but they were later sold off as they just didn’t get used enough. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 6, 2023 Share Posted September 6, 2023 Maybe they've changed, but the aftermarket forward facing seats have never looked as stout as they should. The puma ones have always looked much more up to the task. Worth remembering the required reinforcing underneath too. Quote Link to comment Share on other sites More sharing options...
fmmv Posted September 6, 2023 Share Posted September 6, 2023 YRM do the metalwork needed to convert the rear tub. 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 6, 2023 Share Posted September 6, 2023 3 hours ago, landroversforever said: Maybe they've changed, but the aftermarket forward facing seats have never looked as stout as they should. The puma ones have always looked much more up to the task. Worth remembering the required reinforcing underneath too. The one I have is pretty solid. I think ET used to do two. A basic one that did look a bit flimsy and the lock and fold one I have. Just the new version of the lock and fold one on there now though. 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 7, 2023 Share Posted September 7, 2023 15 hours ago, landroversforever said: Maybe they've changed, but the aftermarket forward facing seats have never looked as stout as they should. The puma ones have always looked much more up to the task. Worth remembering the required reinforcing underneath too. More than once, I think. The basic and not terribly robust type were replaced by ET with their lock and fold type over a decade ago, probably about 15 years, but they looked more akin to something you’d see next to the wheel chair bay on a public bus. The type the do now is more recent and more in the style of LR. 1 Quote Link to comment Share on other sites More sharing options...
Lockylockwood Posted September 8, 2023 Author Share Posted September 8, 2023 On 9/6/2023 at 12:38 PM, Anderzander said: Ahh they have a new design … and my god the price has gone up. https://www.exmoortrim.co.uk/seating/defender-load-area/loc-and-fold-right-hand.html Blimey that’s super expensive. And that’s how much it costs for each. Im gonna see if there’s any online that may suit for about £1000 for 2 seats. Wish me luck. 1 Quote Link to comment Share on other sites More sharing options...
Lockylockwood Posted September 8, 2023 Author Share Posted September 8, 2023 On 9/6/2023 at 12:39 PM, Snagger said: I used a pair of Defender front seats for the second row, with 2mm steel sheet “tins” acting as the inboard legs and the outboard rail bolted to the existing but reinforced wheel boxes. Work well and have the same head room and leg space as using the folding late Defender rear seats. If you use captive fixings, or better still, a quick release system, then you would retain the load bay flexibility. http://www.nickslandrover.co.uk/only-a-few-jobs-left-to-do/ I had the old Exmoor folding rear seats, but they are narrow and, when mounted as intended, are difficult to access or even lock the legs or backs in position. Their seat belt geometry was dire, too. Because of all that, I moved them outboard with the hinges set on 1/2” plinths to allow the base frame to clear the wheel box. Sorted all of the issues except for head room for adults, but they were later sold off as they just didn’t get used enough. That looks pretty good actually. Only thing is would it be sturdy for 2 young children? I have a 6 month old and a 2 year old Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 8, 2023 Share Posted September 8, 2023 Here’s mine .. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 8, 2023 Share Posted September 8, 2023 This is the first type of lock and fold … the one that … On 9/7/2023 at 5:16 AM, Snagger said: looked more akin to something you’d see next to the wheel chair bay on a public bus. https://www.ebay.co.uk/itm/334900442117?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=dReaK7aVT9u&sssrc=4429486&ssuid=8IVqfH45Rgq&var=&widget_ver=artemis&media=COPY 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 10, 2023 Share Posted September 10, 2023 On 9/8/2023 at 8:30 PM, Lockylockwood said: That looks pretty good actually. Only thing is would it be sturdy for 2 young children? I have a 6 month old and a 2 year old It is ample for adults, let alone kids. They are standard front seats, mounted more robustly than LR did, using 3mm marine grade alloy for the entire floor and wheel arch tops with 5mm spreader plates for the fixings. Big spreaders were used for the belts mounts, too, with SIII front seat belt lower anchors (the triangular type that bolt to the door sill and B-pillar) inverted atop the roof gutter to give far V8 enter geometry than the usually employed diagonal anchor intended for front seat shoulder mounts (way too low for seats mounted in the rear as they are higher and usually well inboard). I used 12.8 M8 bolts instead of the standard 8.8 M5 or M6. Those mounts aren’t going anywhere. 1 Quote Link to comment Share on other sites More sharing options...
Lockylockwood Posted September 13, 2023 Author Share Posted September 13, 2023 Hi all, just to update I decided to bite the bullet and go with exmoor trim. The wife took a bit of convincing but we got there. Thanks for the help 😬 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 13, 2023 Share Posted September 13, 2023 Great 😊 share some pics when you can Quote Link to comment Share on other sites More sharing options...
fmmv Posted September 13, 2023 Share Posted September 13, 2023 What he said, plus thanks for updating. Quote Link to comment Share on other sites More sharing options...
