bazza Posted February 1, 2007 Share Posted February 1, 2007 Got a 300 tdi defender 90 and the fuel seems to be draining back to the tank over night as its a pain to start in the mornings but if i pump the fuel up on the lift pump before attempting to start its fine, any ideas? lift pump maybe? i have checked for leaks but cannot see any. Quote Link to comment Share on other sites More sharing options...
western Posted February 1, 2007 Share Posted February 1, 2007 could be the lift pump diaphragm is split & allowing fuel to drian back through. only way to tell for certain is to change the lift pump 7 see if it happens after the change. Quote Link to comment Share on other sites More sharing options...
simonb Posted February 1, 2007 Share Posted February 1, 2007 could be the lift pump diaphragm is split & allowing fuel to drian back through. only way to tell for certain is to change the lift pump 7 see if it happens after the change. Either diaphragm or valves in lift pump or air entering elsewhere. The pumps usually start to go when they reach about 100k miles. Even a genuine one is not expensive (£40 IIRC) so if yours is a high miler might be worth changing. Pump ERR5057, gasket ERR2028, also need nuts x2 NRC 9770 and olives x2 NRC9771 Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted February 1, 2007 Share Posted February 1, 2007 Careful Ralph... Someone else doing your part numbers job here... I recon you either need to fight it out in the quick draw round or just rest easy, let it slide and have a good time.. Quote Link to comment Share on other sites More sharing options...
bazza Posted February 1, 2007 Author Share Posted February 1, 2007 Either diaphragm or valves in lift pump or air entering elsewhere. The pumps usually start to go when they reach about 100k miles. Even a genuine one is not expensive (£40 IIRC) so if yours is a high miler might be worth changing.Pump ERR5057, gasket ERR2028, also need nuts x2 NRC 9770 and olives x2 NRC9771 She's just coming up to 95K, will get a pump in the morning and see how it goes. Thanks Quote Link to comment Share on other sites More sharing options...
western Posted February 1, 2007 Share Posted February 1, 2007 Careful Ralph...Someone else doing your part numbers job here... I recon you either need to fight it out in the quick draw round or just rest easy, let it slide and have a good time.. haven't got the energy for a fight reckon bazza will only need the lift pump & gaskets, I've never changed the tube nuts or olives on my much higher mileage 200Tdi [yes I know bazza's is a 300Tdi] Quote Link to comment Share on other sites More sharing options...
Abe Posted February 2, 2007 Share Posted February 2, 2007 Hi Bazza Why dont you by-pass the Lift pump and install an Electric Initially I had both installed & in the end went for the electric Up side - Motor doesnt have to turn over to bring the fuel up from the pump - The motor will fire up most mornings even without heat (ambient temp 5 down to minis 2c) at the moment jan - less wear & tear on your Starter motor - most morning the motor 300tdi will fire in about a turn of the motor! - because on Av you're pumping more fuel than needed the returned "warmer fuel" via the return pipe will keep your fuel in general, warmer - as you pumping from the tank-end of the system rather than drawing the fuel right through the system - the chances of drawing air is reduced down side - if you have no juice in the battery you may have encounter problems although to date I have had no problem even with a flatfish battery as the pump takes away the need to turn the motor over as long. - a replacement lift pump is about 18 quid whereas a electric is about min of 40 On mine I have a pump on the main tank pumping through a in-line heater & on to the main filter & a 2nd to bring fuel from the 2nd tank to the main tank A bit of overkill although I got tired of cleaning the carp out of the military tank switch which used to feed the main fuel pump happy trails abe Quote Link to comment Share on other sites More sharing options...
simonb Posted February 2, 2007 Share Posted February 2, 2007 haven't got the energy for a fight reckon bazza will only need the lift pump & gaskets, I've never changed the tube nuts or olives on my much higher mileage 200Tdi [yes I know bazza's is a 300Tdi] Only got the numbers to hand cos I did this job a few months ago... . On a 300Tdi, the nuts and olives will be trapped on the old pump pipe stubs ( like when you undo a domestic plumbing compression joint) so you need new ones. Quote Link to comment Share on other sites More sharing options...
michael calvert Posted February 2, 2007 Share Posted February 2, 2007 Only got the numbers to hand cos I did this job a few months ago... . On a 300Tdi, the nuts and olives will be trapped on the old pump pipe stubs ( like when you undo a domestic plumbing compression joint) so you need new ones. do you not put the pipes back in? ie just a new pump? Quote Link to comment Share on other sites More sharing options...
simonb Posted February 3, 2007 Share Posted February 3, 2007 do you not put the pipes back in?ie just a new pump? Nope, if someone posts a pic of the pipes it will be obvious, the nylon pipe is heat shrunk over one part of the union, it literally is like a mini double ended compression joint. Quote Link to comment Share on other sites More sharing options...
bazza Posted February 9, 2007 Author Share Posted February 9, 2007 FIXED HER New fuel pump done the trick, Thanks for the advice everybody Quote Link to comment Share on other sites More sharing options...
