pigster Posted February 11, 2007 Share Posted February 11, 2007 so then, whats the deal.. is it a case of oil and filters... or is there something esle to it? any electrics that need to be switched or buttons pushed..? its a 2.0d. Does the gearbox need oil changed as well like the D90 does? any help is appreciated. plus what oils for what areas.. ? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 11, 2007 Share Posted February 11, 2007 No computator needed, straightforward enough if there are no electronic problems known. Gearbox uses MTF94 I think... Quote Link to comment Share on other sites More sharing options...
pigster Posted February 11, 2007 Author Share Posted February 11, 2007 so its as straight forward as servicing the 90 then... cool. I shall see what the haynes manual says about amounts etc. Is it necessary to do the gearbox? or even transfer box during a service, or are they necessary? No computator needed, straightforward enough if there are no electronic problems known.Gearbox uses MTF94 I think... Quote Link to comment Share on other sites More sharing options...
white90 Posted February 12, 2007 Share Posted February 12, 2007 you need a 36mm socket to get to the oil filter on the TD4 the fuel filter is in an incredibly awkward place with small fiddly screws the sump guard has to be removed to drain the oil the brake pads are east to change though. Quote Link to comment Share on other sites More sharing options...
pigster Posted February 12, 2007 Author Share Posted February 12, 2007 nice.. this will be fun then.. you need a 36mm socket to get to the oil filter on the TD4the fuel filter is in an incredibly awkward place with small fiddly screws the sump guard has to be removed to drain the oil the brake pads are east to change though. Quote Link to comment Share on other sites More sharing options...
najw Posted February 12, 2007 Share Posted February 12, 2007 or even transfer box Quote Link to comment Share on other sites More sharing options...
Les Brock Posted February 12, 2007 Share Posted February 12, 2007 Hope you're better at servicing, than you are at driving What's the price of a scrap Freeloader anyway Quote Link to comment Share on other sites More sharing options...
pigster Posted February 12, 2007 Author Share Posted February 12, 2007 ha blinking ha... Hopefully dirt cheap by the time I have finished with it.. can I drive your motor yet les - - please... please Hope you're better at servicing, than you are at driving What's the price of a scrap Freeloader anyway Quote Link to comment Share on other sites More sharing options...
Blippie Posted February 15, 2007 Share Posted February 15, 2007 Voila ... Freelander maintenance checklist: Available from: http://www.cameltrophyvehicles.com/downloa...nance_Sheet.jpg Cheers Blippie Quote Link to comment Share on other sites More sharing options...
pigster Posted February 16, 2007 Author Share Posted February 16, 2007 wow -- cheers mate Voila ... Freelander maintenance checklist: Available from: http://www.cameltrophyvehicles.com/downloa...nance_Sheet.jpg Cheers Blippie Quote Link to comment Share on other sites More sharing options...
