MogLite Posted February 13, 2007 Share Posted February 13, 2007 Okay - the water pump on my 98 4.6HSE Rangie has failed. No drama, its happened before, it'll probably happen again. But I can't get the viscous nut undone. I know its LH thread. So if I'm standing at the front of the vehicle - I need to move the spanner, from 12o'clock round to 3o'clock ? If I'm right - its bl00dy tight Quote Link to comment Share on other sites More sharing options...
Chris Abel Posted February 13, 2007 Share Posted February 13, 2007 Okay - the water pump on my 98 4.6HSE Rangie has failed. No drama, its happened before, it'll probably happen again.But I can't get the viscous nut undone. I know its LH thread. So if I'm standing at the front of the vehicle - I need to move the spanner, from 12o'clock round to 3o'clock ? If I'm right - its bl00dy tight Its definitly a LH thread i used a chisel and hammer to get mine off, its difficult to crack the nut sometimes with a spanner when the fan belt has spring in it. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted February 13, 2007 Share Posted February 13, 2007 cracked the thread on my fan nut with a lump hammer to the end of the spanner, did the trick Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted February 13, 2007 Share Posted February 13, 2007 Moglite, Some Rover V8s are RH, some are LH. Personally I don't bother trying to remember which model does what, on any engine. Go from the basic principle, which applies to any engine PROVIDING you know which way the fan rotates when the engine is running. You ALWAYS loosen the nut in the SAME direction the fan rotates. That's it, simple. When you do it up again, you don't need a lot of force, just nip it up to make sure it's seated. The normal rotation of the engine will keep it tight enough. HTH Quote Link to comment Share on other sites More sharing options...
MogLite Posted February 14, 2007 Author Share Posted February 14, 2007 You ALWAYS loosen the nut in the SAME direction the fan rotates.That's it, simple. Thats a good check David - I'll give it a look at tonight. I was holding the pulley with an industrial boa constrictor, and beating the viscous spanner with a dead-blow hammer. Maybe the hammer and chisel will have to come out Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 14, 2007 Share Posted February 14, 2007 One that worked on the RR was to jam a thing (Eg screwdriver, bit of bar, small child) into the point where belt meets pulley so that the further round it goes the tighter it gets. Mr Morfee suggested it and we all went "Naaaaaahh", then it worked first time. So he does know at least one useful thing Quote Link to comment Share on other sites More sharing options...
MogLite Posted February 14, 2007 Author Share Posted February 14, 2007 Well David gets the prize - its a regular thread - so I was doing it up !! Waterpump is all off - just the ultra stubbon gasket to go. Thanks Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted February 14, 2007 Share Posted February 14, 2007 One that worked on the RR was to jam a thing (Eg screwdriver, bit of bar, small child) into the point where belt meets pulley so that the further round it goes the tighter it gets. Mr Morfee suggested it and we all went "Naaaaaahh", then it worked first time. So he does know at least one useful thing That'd be one more than you then Fridge Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 14, 2007 Share Posted February 14, 2007 I did say "at least one" anyway I know nuffink Quote Link to comment Share on other sites More sharing options...
Andy Posted February 15, 2007 Share Posted February 15, 2007 I did say "at least one" anyway I know nuffink Fridgefreezer is 100% Correct Quote Link to comment Share on other sites More sharing options...
